Old 30th May 2018, 9:52 pm   #41
AC/HL
AC/HL's Avatar
Default Re: AVO Model 9 Mk IV variation
Originally Posted by pmmunro View Post
If you do have serial numbers and details, it would be useful to have these on the Avometer surrvey thread, perhaps as well as here.
This thread was split from the parent by request. I'd assume that anyone making a record of serial numbers would know to look in either thread, but it certainly won't do any harm to duplicate them if desired.
AC/HL is offline
Old 4th Aug 2018, 8:13 am   #42
Superscope
Update to the Mk IV research for those interested.
Based the Data I have accumulated, the Serial Number Move from the Scaleplate to
the Label on the Outside, seems to have occurred in January 1970.
Feel free to let me know if you have a Mk IV that contradicts this.
My Data Sample is only 20 Units, so not as big as I would like it.
The Move from a Black Plastic Case, to the Grey/Green Case also
appears to have happened in January 1970.
I do not have any records of the Grey/Green Case having the Serial number Printed on the
Scaleplate, but I do have records of the Black Case having Scaleplate and Label Serial
Numbers.
I would guess then, that there were a number of Black Cases that needed to
be used up first when the changes were made.
Again, if anybody has Mk IV's that contradict this, feel free to let me know.
Ian
Superscope is offline
Old 16th Dec 2018, 12:53 am   #43
My Avo 9 mk4 do not have serial number on dial plate or label on the case. The case is plastic, color grey, and the movement looks original, it has been in my own for 25 years or more. Inside standard in "V"
