Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Wanted (private buyers only, no swaps)
Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Reply
Old 18th Jul 2021, 3:39 pm   #1
tonewheelkev
Default VU Meter for B77/PR99 etc.
Have a B77 (and a PR99) both working....but need 1 X vu meter mechanism.
OR...someone with the skill to refit kyboshed spring to the existing one.
Here's a pic.....there is some corrosion....but that isn't preventing the pointer from swinging!!
tonewheelkev is offline   Reply With Quote
Old 21st Jul 2021, 10:57 pm   #2
electroanorak
electroanorak's Avatar
Default Re: VU Meter for B77/PR99 etc.
I have a box of PR99 spares. I will look tomorrow. I am sure I have them.
Daniel.
electroanorak is offline   Reply With Quote
Old 22nd Jul 2021, 9:56 am   #3
tonewheelkev
Daniel.
That'd be wonderful!
PM'd
Old 23rd Jul 2021, 5:11 pm   #4
Electronpusher0
Are you sorted Kev? if not I have some spare VU meters that have identical movements in them, I have already removed one to rplace the movement in a faulty signal strength meter and it works well.
Peter
Electronpusher0 is offline   Reply With Quote
Old 23rd Jul 2021, 5:45 pm   #5
tonewheelkev
Smile Re: VU Meter for B77/PR99 etc.
Peter
I'd never thought there might be something else with an identical movement!!
Good spot Peter!
Daniel hasn't got back yet....but I'll get back to you later if that's OK...
Old 27th Jul 2021, 5:25 pm   #6
Electronpusher0
Hello Kev, I got it slightly wrong. The meter I replaced was identical to yours.
I took the movement out from the faulty one, it was just stuck in place, and replaced it with the movement from the spare VU meter, it was an exact fit.
I had to paint the pointer white with a thin coat of Humbrol enamel.
The solder lugs are 11.2mm between centres, the outside of the U shaped magnet is 14.1mm across. The pointer is 28mm long from the centre of the pivot.
Again the movement is just lightly stuck in and comes free with a bit of gentle persuasion.
Its 300uA fsd.
I have another spare which you can have free if you want it.
Peter
ID:	238323   Click image for larger version
ID:	238324   Click image for larger version
Old 27th Jul 2021, 5:28 pm   #7
tonewheelkev
I'd love to give it a go!
PM'd you....
Old 31st Jul 2021, 5:57 pm   #8
tonewheelkev
Still on the lookout...so bump!!
Old 7th Aug 2021, 2:52 pm   #9
tonewheelkev
...one last try...!!
Reply
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright ©2002 - 2021, Paul Stenning.
