16th Jul 2012, 5:06 pm | #1 |
Would you advise this method to restore old pinchrollers or rubber parts?
Hi again.
If i have old audio or video equipment, with old pinchrollers that aren't cracked or hardened that only look a bit glossy or dirty, would it be advisable to restore them by softly sanding them with a emery board or a fine sandpaper or something else that doesn't hurt much the rubber? I would like to avoid replacing those parts if possible or even to resort to rubber rejuvenator. More tips would also be very much welcome. thank you in advance! |
16th Jul 2012, 5:13 pm | #2 |
Re: Would you advise this method to restore old pinchrollers or rubber parts?
This is a standard technique when restoring old pinch rollers or idler wheels. It doesn't always provide a complete fix but usually results in some improvement.
16th Jul 2012, 6:28 pm | #3 |
Well i recall reading this method a while ago but i thought it would be safer to ask someone who already did it. I guess i need to be very smooth with it so that i don't introduce ruff edges to the rubber resulting in a damaged tape afterwards.
17th Jul 2012, 5:52 pm | #4 |
I've resorted to that method on rim drive rubber clad reels, the one that suffer from a permanent indent from the small dc motor spindle (in the off position)
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it! |
22nd Jul 2012, 2:15 pm | #5 |
I did get away with putting a very bad turntable idler in a lathe and using a very sharp tool to turn off the aged layer. The surface was then soft and even and worked great. I dont know if I was just lucky that time. You also do need a lathe to do this!
