12th Mar 2011, 4:00 pm | #1 |
3M Inductive Tone Probe
i'm looking for some info about a 3M Inductive Tone Probe from 3M Telecom Systems, used for APICS (PCM) field units ? Assy no XE-1014-7617-6 / CE-1006-7740-6 The pen is 185mm long, 10mm diameter, cord and has a 6.3mm connector Inside the connector is a 3 wire cable (2+GND) connected and should be connected to a (LF) receiver (33Khz ??). The pen is closed and has metal top (test pin) My question is, what is inside ? Only a transformer, an amplifier, is external power needed I don't want to open it. Maybe someone has used such a probe ? pic attached thanks Peter |
28th Mar 2011, 1:43 am | #2 |
Re: 3M Inductive Tone Probe
Some more info,
i opened the shielded probe case. Inside is PCB with a N-Fet (max 100 MHz) high impedance (10Meg) transistor Amp. stage, open drain, with possible utility voltage 15V. The remaining/missing circuit is in the test equipment, i think. Used working frequency appr. 30 MHz How looks the missing circuit ? For what else can the probe be used ? Maybe input Amp for a selective voltmeter ? Peter |
