Old 16th Jan 2018, 2:00 pm   #1
defender
Default 8 track tape foam strip
What does everyone use?
I looked on ebay but it's all from the US
defender is offline
Old 16th Jan 2018, 2:25 pm   #2
llama
llama's Avatar
Default Re: 8 track tape foam strip
Draught excluder has been suggested.
Graham
Half my stuff is junk - trouble is, I don't know which half!
llama is offline
Old 16th Jan 2018, 2:25 pm   #3
Reelman
Reelman's Avatar
I’ve used foam draft excluder, it looked to me exactly the same substance as was already fitted. Don’t know if it is still available but it consists of white foam rubber with double sided tape on one side and a shiny transparent layer on the other. Best to clean the shiny side before using to insure there are no traces of adhesive.
Hardest part is removing the old strip.
All can be done without splitting the case.
Good luck,
Peter
Reelman is offline
Old 16th Jan 2018, 5:41 pm   #4
sp10mk11
sp10mk11's Avatar
I too use foam draft excluder which I get from a local DIY shop (a rarity I know) some times it is white and other times it has been brown.
I gave up on ebay as it was a very dense type of foam that was unsuitable as a pressure pad.
Opening some can be a nightmare but once you get used to the various designs they are not too bad, some even use plastic rollers rather than rubber.
Good luck
Gary
sp10mk11 is offline
