3rd Mar 2016, 1:30 pm | #1 |
Fostex B16 not recording
Hi
My Fostex B16 registers the audio going when setting levels. Upon activation of record/play the led's still register the audio but upon play back it hasn't recorded anything? Any ideas anyone please? Many thanks |
3rd Mar 2016, 2:27 pm | #2 |
Re: Fostex B16 not recording
Has it ever worked properly?
When you say "it hasn't recorded anything", has any previous programme been erased?
3rd Mar 2016, 7:16 pm | #3 |
Hello Julie, thanks for replying.
It has been in storage for about 4 years. Yes, it has worked previously. However I am using an old tape with it, a Quantegy 456. There is a little oxide shedding but not a lot. it still plays back the previous recorded material. I'm wondering if the tape is the issue. Kind Regards Alan. |
4th Mar 2016, 4:01 pm | #4 |
If it's not erasing the old material, chances are it's not even entering record mode properly. (You would be able to tell for sure by using an oscilloscope to look for erase voltage on the appropriate windings of the erase head, and bias voltage on the appropriate windings of the record / play head.)
Are all tracks affected, or only some? If only some, suspect the record safety switches; if all tracks, suspect a missing PSU voltage rail.
4th Mar 2016, 8:09 pm | #5 |
Look carefully at the record head. It may have sticky shed tape gunk on it. If so, clean the head - and the entire tape path - thoroughly. Then use a tape not prone to sticking and shedding. The machine may still have a record problem but at least you can eliminate the tape.
7th Mar 2016, 7:49 am | #6 |
I've had similar problems with gear that's not been used for a while including a Tascam 38 with motor logic issues and two mixing desks with dead channels etc.
Let's hope its your tape, Andy.
7th Mar 2016, 7:59 am | #7 |
I've had similar issues with stored vintage recording gear; a Tascam 38 I had which worked ok previously developed problems with the logic controlling the motors and not switching relays for PB and record. Also had problems with mixing desks with dead channels etc.
Properly speaking your deck should be set up before every session including cleaning the heads and setting the bias levels. The heads and any iron work should be de magnetised every so often too. Hope its just the tape, not simple things to work on these beasties. Good luck, Andy.
