17th Aug 2018, 12:54 pm | #1 |
Can anyone identify this chassis?
Im looking at the chassis from a Collaro RC456 high fidelity radiogram. I can't identify the maker of radio chassis, I can't find any trader sheets for Collaro.
I have looked at the chassis and rear cover and there is no ID plate to be found, can anyone help?
If it ain't bust don't fix it |
17th Aug 2018, 1:17 pm | #2 |
Re: Can anyone identify this chassis? 🤔
RC456 is the model number of the Collaro record autochanger deck, manual for that is here:
https://nvhrbiblio.nl/schema/Collaro_RC456.pdf Any pics of the radiogram as a whole? Lawrence. |
17th Aug 2018, 1:20 pm | #3 |
It's unlikely you'll find Trader sheets for Collaro since that's the make of the deck, not the radiogram.
The chassis looks very bog standard 4+R with an easy layout for a few cap replacements or even reverse engineering. The valve lineup might help with identity- if it's anything unusual and not just Mullard / Philips standard. Photos of the whole radiogram might be helpful, if it still exists.
17th Aug 2018, 1:25 pm | #4 |
Standard chassis of this type were made to be installed in existing cabinets, sometimes
by hobbyists, but more often by retail furniture shops wishing to include a r/gram in their product ranges. |
17th Aug 2018, 1:44 pm | #5 |
That's about what I thought, I'll get a phot of the cabinet, and get the valve no later,
The problem is with the radio /amp very low volume and only being a "learner" a ™ trader sheet will be invaluable
17th Aug 2018, 1:44 pm | #6 |
Fidelity ?
17th Aug 2018, 1:51 pm | #7 |
It looks similar to a McCarthy brand (Felgate Radio Ltd) chassis from the mid-1950s that I refurbished a few years ago.
They made chassis for DIYers and multiple shop retailers to put into "own brand" cabinets/radiograms, etc. If you have the Radio & TV Servicing books from the 1950s, some McCarthy models are covered. Trader/ERT/RER service sheets may also have covered some McCarthy models of this era. |
17th Aug 2018, 2:06 pm | #8 |
Compared with many other RG Innards that turn up this one seems to be very well laid out and uncluttered-ideal for working on if necessary. Most of these chassis's were quite basic but the sound was often very impressive [at the time] especially in a substantial cabinet. If that's the "case" here it could be a winner on both fronts!
Dave W |
17th Aug 2018, 2:24 pm | #9 |
That's a very good looking chassis, great to work on, quality components as well especially with the screened transformer.
Neil
17th Aug 2018, 2:36 pm | #10 |
The Valve line up is. 6bwn . 5y3gt. 6at6. 12ah8. 6bj6,
Cabinet photos to follow
17th Aug 2018, 2:37 pm | #11 |
Before anyone asks, the 5Y3gt was the search clue....similar chassis as this:
https://www.vintage-radio.net/forum/...d.php?t=107587 EDIT: Post crossed....I ID'd the 5Y3gt from the photo in Post#1. Lawrence. |
17th Aug 2018, 3:04 pm | #12 |
The chassis looks almost identical
17th Aug 2018, 3:21 pm | #13 |
I haven't seen the cabinet yet, but the owner says that this is the model, just now need to find the circuit diagram, thanks for the help
17th Aug 2018, 3:37 pm | #14 |
Some Portadyne stuff used the same valve line up.
Lawrence. |
17th Aug 2018, 4:50 pm | #15 |
I can't see a dedicated PU socket Clay S . Was the deck hard wired in via the grey lead perhaps?
Dave W |
17th Aug 2018, 4:53 pm | #16 |
It was hard wired in with speaker cable, along with the power lead
17th Aug 2018, 4:55 pm | #17 |
Ok thanks for that. I automatically looked for a "pick up" socket
Dave |
