6th May 2021, 2:11 pm | #1 |
Dual can capacitor replacement
I am restoring a Philips B4G01U radio. The dual can capacitor contains 1x 100 Mfd @ 275 v0lts and 1x 50 Mfd @50 volts. Have sourced 100Mfd but cant seem to locate a 50Mfd @ 275 volts. Any suggestions welcome. Regards Mike |
6th May 2021, 2:15 pm | #2 |
Re: Dual can capacitor replacement
Try 47uF which is the modern equivalent.
Cheers Mike T
6th May 2021, 2:21 pm | #3 |
Will Research online,
Thanks Mike |
6th May 2021, 2:25 pm | #4 |
Either the 47uF 450v or the 68uF 400v here will do the job https://www.cricklewoodelectronics.c...ce.html?page=2 Jerry
6th May 2021, 2:26 pm | #5 |
Is the 50uF 50V component a cathode decoupler? If so, I would be inclined to just make it a separate 47uF 50 or 63V unit anyway- combined HV/LV units make me worry about the effects of internal faults! (admittedly probably unusual). Dual/multiple caps are a manufacturing economy as opposed to a performance advantage as it is.
6th May 2021, 3:55 pm | #6 |
