29th Apr 2021, 4:31 pm | #161 |
Re: EKCO U122 - Restore or spares?
Lawrence I was reading some threads about this. Is there a limit to this capacitor size? The reservoir cap obviously has a size limit,but opinions seem to vary on whether bigger is always better with regards to smoothing caps, with the possibility of stressing the rectifier upon switch-on. Is this a theoretical or a real possibility?
29th Apr 2021, 5:23 pm | #162 | |
The 33uF would be an electrolytic, remember not to connect the -ve to chassis but to the same line as the -ve of the reservoir capacitor which is the switched mains Neutral line, if the hum you are getting is due to or partly due to the HT ripple voltage then an RC filter should help to reduce it. Basically because there's no ripple cancellation in the replacement transformer then a CRC filter (aka a pi filter) fed from the rectifier should help compensate for that, the first C is already there in the form of the reservoir capacitor hence just adding an R and C to complete the pi filter, you could use a choke instead of a resistor as that would perform better but finding a space for it might be a problem. Schematic wise (Trader) cut out the short horizontal line that's connected to the +ve of C28 and replace it with a 220 Ohm resistor, then from the right hand side of that resistor connect the +ve of the 33uF capacitor and connect its -ve to the same line that the -ve of C28 is connected to. Lawrence |
29th Apr 2021, 10:29 pm | #163 |
Thanks Lawrence, much appreciated.
I'll have a go at implementing the CRC filter (aka a Pi filter) over the weekend. I've had a look at several online Pi filter calculators so would be interested in how you arrived at a 220 Ohm and a 33uF ?
BVWS Member |
30th Apr 2021, 10:32 am | #164 | |
The initial 220 Ohm value was arrived at from a Hacker GP42 schematic. Lawrence. Last edited by ms660; 30th Apr 2021 at 10:37 am. Reason: words change |
30th Apr 2021, 2:14 pm | #165 |
I managed to lash-up a temporary Pi filter following Lawrence's detailed advice and guidance about where to connect the 220 Ohm resistor and 33uF electrolytic capacitor.
RESULT - the hum has all but disappeared and can only be heard very faintly when the volume control is turned to a minimum! I'll review Lawrence's additional advice on options to fine tune the Pi filter "I didn't go for a lower voltage drop than 10 volts because I don't know what the max hot switching current limit of rectifier is, so on reflection maybe try with 470 Ohms instead of 220 Ohms and see what difference the lower HT makes to the performance ... " I'll carefully check the voltages on V5 and V4 for both options. I am, however, very impressed and pleased with this outcome - something I've never used before! So thanks again to Lawrence for this and for introducing me to the world of the Pi filter! 😁
BVWS Member |
30th Apr 2021, 3:06 pm | #166 |
Well done to you and to Lawrence for getting this sorted
30th Apr 2021, 3:12 pm | #167 |
What ever you do don't try and increase the value of the added capacitance or reduce the value of the added resistance, in fact the lowest value capacitor in conjunction with the highest value of the added resistor in terms of acceptable ripple hum and performance the better just in case the rectifier doesn't like it.
Lawrence. Last edited by ms660; 30th Apr 2021 at 3:22 pm. Reason: extra info |
30th Apr 2021, 4:06 pm | #168 |
Checked the valve pin voltages with the 220 Ohm resistor and 33uF electrolytic capacitor- figures in brackets are from the Service Sheets:-
AC Mains Supply : 246V AC V5 Rectifier UY41 Anode : 223V AC (215V AC) Cathode : 244V (218V) V4 Output Valve UL41 Anode : 212V (213V) Screen : 75.8V (76V) Control Grid : -ve 4.0V Apart from a reduced bias on V4 (previously -ve 4.38V) these figures don't look too bad to me - I am of course using a DMM and not an AVO. @Lawrence - you mentioned that I could " ... use a choke instead of a resistor as that would perform better" - any recommendations for a value and type?
BVWS Member |
30th Apr 2021, 4:36 pm | #169 | |
With a suitable choke you can use a lower value of filter capacitor compared to an RC filter to get the same ripple voltage reduction. Lawrence. |
30th Apr 2021, 5:38 pm | #170 |
Didn't appreciate that these 10H chokes were so chunky, size and weight, so I think I'll just stick with the 220 Ohm resistor and 33uF electrolytic capacitor meantime. There is enough space under the chassis to fit a small tag strip to safely hold these components.
That about wraps up the electronics for this set which has been substantially rebuilt! Just pleased that I don't have to make an economic return on such projects! Thanks to everyone for their help and support, particularly Lawrence for his valuable contributions. Now back to those cosmetic case and knob issues ...
BVWS Member |
5th May 2021, 12:52 pm | #171 |
A quick follow up question as I'm very impressed with the impact of the Pi filter on the level of hum with this set.
Of course it got me thinking about the hum on my Bush DAC90A and to what extent a Pi filter with the same value of components would be as effective - 220 Ohm resistor and 33uF electrolytic capacitor. If these values aren't applicable then how would one go about calculating the correct values. Lots of online Pi filter calculators but not sure which ones I should trust?
BVWS Member |
5th May 2021, 2:50 pm | #172 |
The bush wasn't intended as a high end music centre. With this in mind, I do t think the hum in the bush is unacceptable.
I would leave it as is. If it's sound quality you're after, try a Murphy or a German set |
6th May 2021, 12:15 pm | #173 |
Thanks Gabe - I've never expected hi-fi performance from these 1950's vintage valve sets but if the hum can be tamed, as I have done with the EKCO U122, then why not with other sets? It's all a voyage of discovery and part of my ongoing education!
BVWS Member |
6th May 2021, 5:23 pm | #174 |
Of course Donald. My comment appears a bit more confrontational than I intended. Apologies.
Did you manage to sort out bluetooth on the Bush? |
6th May 2021, 7:51 pm | #175 | |
I was hoping that Lawrence would perhaps give me a steer on this? As for the Bush DAC90A Bluetooth Project, I'm hoping to draft an update in the next day or two.
BVWS Member |
6th May 2021, 8:34 pm | #176 |
Well, he did say
"the lowest value capacitor in conjunction with the highest value of the added resistor in terms of acceptable ripple hum and performance the better just" Depending on how healthy your rectifier is, if you really want to go down this route (it's your radio), why don't you try a 330 resistor and 10uf cap as an experiment? |
7th May 2021, 10:14 am | #177 | |
That said, rectifiers have limits, the UY41's limits haven't been reached in the Bush DAC90a circuit, see if you can spot which limits haven't been reached, one in particular can have an effect on the ripple voltage. Lawrence. |
10th May 2021, 10:21 am | #178 | |
"I generally reduce the hum level on Bush DAC90A receivers by shunting the reservoir capacitor with a further 32 uF. This is well within the limit for the UY41 at the current drawn by this receiver."
BVWS Member |
10th May 2021, 11:09 am | #179 |
That's the one, the reservoir limit that is.
Lawrence. |
10th May 2021, 7:57 pm | #180 |
The Valve Museum page states:-
'To limit the current to a safe value for the UY41 the series resistance needs to be at least 210 Ohms. The maximum reservoir capacitor must be limited to 50 μF' Looking back at the quote in my earlier Post how would one shunt the reservoir capacitor with a further 32 uF and not exceed the maximum? Not sure of the current drawn by the Bush DAC90A?
BVWS Member |
