Old 4th Nov 2021, 6:08 pm   #41
HoverJohn
Default Re: When is a part “dead”….(length of string question)
I was wondering if anyone’s used adhesive cable tie anchors and just taken the easy route?
HoverJohn is offline   Reply With Quote
Old 4th Nov 2021, 6:39 pm   #42
Hartley118
Hartley118's Avatar
That works too - if you’ve got something to tie the cable ties to.
Martin
BVWS Member
Hartley118 is online now   Reply With Quote
Old 4th Nov 2021, 7:19 pm   #43
Uncle Bulgaria
Originally Posted by HoverJohn View Post
All grid couplers ordered too god knows how it didn’t go bang when I turned it on.
I've found this document very helpful to avoid the bang and associated sinking of the heart.
I don't agree with everything he says, but it's a good aide memoire to be careful to avoid having to fix extra problems caused by being too keen.
File Type: pdf Steps To First Powering On Old Equipment.pdf (625.5 KB, 21 views)
Uncle Bulgaria is offline   Reply With Quote
Old 5th Nov 2021, 12:12 am   #44
Refugee
Refugee's Avatar
Originally Posted by Station X View Post
I measure leakage current by measuring the voltage across a resistor connected in series with the power feed to the capacitor. If a 10k resistor is used each volt measured across it represents 10mA of leakage current.
It looks like you have had a decimal point slip there.
I have just worked it out at 100uA.
Refugee is offline   Reply With Quote
Old 5th Nov 2021, 8:13 am   #45
Senior moment. I should have said 100R as used in this reformer:-
https://www.vintage-radio.com/projec...-reformer.html
10k is the current limiting resistor.
Keep the soldering iron hot.
Old 7th Nov 2021, 11:58 am   #46
HoverJohn
Ok I have the advantage that I knew it was all working not that long ago and powered up recently.
Just recapped the pre amp and taking on amp next …. That has a few drifty resistors too.
JB
ID:	245226   Click image for larger version
