Old 29th Jan 2019, 9:17 pm   #1
19Seventy7
19Seventy7's Avatar
Default Coax to 3.5 aerial.
Hi, I have just picked up a tiny 5.5 inch b/w crt (Working) to use while my colour set is in need of repair
It has a 3.5mm ext. aerial socket; is there any way i can create a custom coax to 3.5mm cable?
I have read that headphones can work so could i possibly cut the jack wire off an old pair of headphones, and the wire to an old coax cable and join the wires? It will only be temporary.
Thanks
19Seventy7 is offline
Old 29th Jan 2019, 9:22 pm   #2
60 oldjohn
Default Re: Coax to 3.5 aerial.
How about one of these? https://www.ebay.co.uk/itm/Coax-Fema...frcectupt=true
John.
60 oldjohn is offline
Old 29th Jan 2019, 9:25 pm   #3
G6Tanuki
G6Tanuki's Avatar
You mean one of these?
https://www.kenable.co.uk/en/video-c...383486373.html
All of 47 pence each; why bother making your own?
G6Tanuki is offline
Old 29th Jan 2019, 9:34 pm   #4
19Seventy7
19Seventy7's Avatar
Thank you for the replies. I was just wondering as I'd have liked to try and get a picture tonight, but I think it'd be best to wait.
Thanks
Old 29th Jan 2019, 9:44 pm   #5
toshiba tony
toshiba tony's Avatar
Come on with your Hitachi!!!! Put the correct part of the circuit on here and I'll id your faulty components. Lawrence mentioned the site it's on but I'm struggling to download.
toshiba tony is offline
Old 29th Jan 2019, 11:05 pm   #6
Graham G3ZVT
Graham G3ZVT's Avatar
Thanks
Improvise something if you want, what's the worst that could happen?
In all seriousness, I prefer a short "pigtail" of thin coax, even audio screened lead, with suitable connectors on each end, over a rigid adaptor, because less strain will be put on the jack socket.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 29th Jan 2019, 11:10 pm   #7
19Seventy7
19Seventy7's Avatar
Would literally cutting two bits of wire, 1 coax, 1 headphones and twisting them together (covering with electrical tape) and plugging in and playing work?
I don't really want to chop up the coax lead if there's no point.
Thanks
Old 30th Jan 2019, 12:25 am   #8
Graham G3ZVT
Yes. If you've got a reasonably strong signal, I'd expect a perfect picture, despite the mismatch.
What make & model is it?
Graham.
G3ZVT
Old 30th Jan 2019, 6:13 pm   #9
19Seventy7
19Seventy7's Avatar
I will try making one. I have a Maxims 5.5 inch b/w TV.
They’re generic brands with many names.
Thanks
Old 30th Jan 2019, 7:22 pm   #10
Refugee
Refugee's Avatar
I have almost certainly got a 3.5mm to coax male lead left over from an RF converter that got used to change the audio offset on a VCR a few years ago.
Refugee is offline
Old 30th Jan 2019, 10:27 pm   #11
19Seventy7
19Seventy7's Avatar
I shall definitely look into buying one, if my custom home made version doesn't work.
I didn't realise that these existed, to be honest.
Thanks
