11th Jul 2014, 1:03 pm | #1 |
KB VC 2 Chassis
Hi All
I have just acquired a KB XV60 which has a strange sticker on the chassis saying VC5 next to the model number but I'm sure this is a VC2! It's working reasonably well "straight out of the box" apart from tetchy line synch, reduced height and a low contrast picture. As this is the first time I have seen this chassis I am interested to know what its stock faults are. Thanks in advance guys. Rod |
11th Jul 2014, 3:39 pm | #2 |
Re: KB VC 2 Chassis
I'm too sure about the XV60. It was made at the time STC were changing over from the VC1 to the VC2. It's easy to identify the chassis. The VC1 has has separate line hold controls for 405 and 625. ECC81 line oscillator valve.Single contrast contrast control.
The VC2 has a single line hold control and uses a PCF802 as the line oscillator. Separate contrast controls for 405 and 625. All versions from VC1 to VC51/2 are excellent. DFWB. |
11th Jul 2014, 4:03 pm | #3 |
Re: KB VC 2 Chassis
Thanks for the info which was helpful.
The set has two contrast controls and a PCF802 line oscillator which confirms it then as a VC2. Have found the circuit details in the STC section of the Vintage TV Service Data disk. I should be o.k now. Thanks Rod |
13th Jul 2014, 2:26 pm | #4 |
Re: KB VC 2 Chassis
Great sets these one of the best dual standard sets made. Faults were generally straight forward to clear especially if you have the circuit diagram available. I spent many happy hours working on these and there were so many around. Enjoy.
Simon BVWS member |
