Old 2nd Jun 2018, 11:22 am   #1
evingar
evingar's Avatar
Default Transistor FBN-L287 / NSN 5961-01-379-3433
I wonder if someone can help me ?
I'm currently trying to salvage a old 1980s Lambda power supply. I've found the reason it's distressed is a faulty power transistor type FBN-L287.
I can't find any data on it in Towers (update 5) or on-line, although I've found a reference to a NATO number NSN 5961-01-379-3433
The date code the device is F8317 (17th week in 1983 ?)
Chris
evingar is offline
Old 2nd Jun 2018, 11:38 am   #2
Argus25
No Longer a Member
Default Re: Transistor FBN-L287 / NSN 5961-01-379-3433
I've come across this sort of dilemma in the past too. There is one way around it , if you cannot identify the transistor, trace out the circuit that the transistor is in and the circuit configuration and see if you can find the rated voltage and current of the supply. Then it becomes a fairly easy task to select a suitable replacement transistor in the same physical package. So if you could provide that info, I could suggest the part to use.
But there may be an equivalents list out there too.
Argus25 is offline
Old 2nd Jun 2018, 2:25 pm   #3
evingar
evingar's Avatar
Thanks for the reply.
I suspect the part is manufactured specifically for Lambda, hence the "L" prefix to the 2nd block of letters and the lack of data in Towers (etc). Naturally, there is no service data available for the PSU, so it looks like I will have to resort to what you suggest.
Chris
evingar is offline
Old 3rd Jun 2018, 8:21 am   #4
evingar
evingar's Avatar
For the record, in case someone else picks this up, When reverse engineering the circuit, it became obvious this part was a power MOSFET, which is quite unusual in equipment of this vintage. This maybe explains why it was a "special" while other components in the PSU were easily identifiable standard parts. Anyway, on knowing that, it measured out OK - the fault was further back in the control circuitry. The power supply is now working and on long term soak.
Chris
evingar is offline
