Television Standards Converters, Modulators etc Standards converters, modulators anything else for providing signals to vintage televisions. |
19th May 2006, 7:24 pm | #1 |
The "Manton" standards converter - repeatable design!!!
aftyer a few evenings work, I've assembled a complete standards converter to Kat's design, and it worked first go! I am looking at a picture of test card "A" as I type this. I have not made any component changes to Kat's Mk2 design, the only issue being I need a better power supply (my "wall wart" is putting a lot of ripple on the -ve line, resulting in unstable synch levels. My fault, not Kat's). I'll try and post a couple of pictures later. Jim. |
19th May 2006, 7:30 pm | #2 |
Re: The "Manton" standards converter - repeatable design!!!
Well done Jim! Have you done a full converter, ie with analogue video capture card, or the version that Kat demo'ed at the NVCF which could replay DVDs or work with a Freeview card?.
19th May 2006, 7:44 pm | #3 |
Hi Jeffrey,
it is the "full" version, currently with an analogue tuner card, so I can go straight from off-air to 405 line, it will also browse the web, Play DVDs, and one or two other tricks that I haven't got to grips with yet! Jim. |
19th May 2006, 7:52 pm | #4 |
Excellent news, Jim
I've now put the Russian portables away and I'm setting up the 405-line PC gear after a relaxing break; so I'll shortly be resuming work on the system. Also work is underway to get a website sorted out; among other things the circuit Jim and I have built will be published there now we know it's repeatable. Getting pictures on vintage television sets; that's what motivates me. It's great to hear that there's another set doing what it was designed for once again. (Well, and a few more things besides; I've found it entertaining that I can browse the web on a 405-line set...) Regards, Kat |
19th May 2006, 10:13 pm | #5 |
Well, a decent power supply fixed most of the problems.......
I've included a photo of the circuit, a couple of screen shots, and a picture of the video waveform taken from the scope. Note the extremely large synch pulses (about -1.5V !) The patterning on the screen shots is a side effect of the camera, and is not apparent on the TV. For completeness: PC - Pentium 4, 1.4GHz processor, 640MB Ram, nVidia FX5200 video card, Hauppage WinTv analogue tuner card, cheap 100MHz LAN card (the cheapest in our local PC shop). Video and synch combiner - Kat's Mk2 circuit. Modulator - Philips PM5511B dual standard pattern generator. Display - Sony 9-90UB dual standard 9" Tv in VHF 405 line mode. Scope - Telequipment D54 (way out of cal, but it gives me a rough idea.....). Power supply - Advance PMG 12V linear module, though any well regulated and smoothed unit will do. Jim. |
19th May 2006, 10:39 pm | #6 | |
Regards, Kat |
19th May 2006, 10:42 pm | #7 |
Err... try swapping R36 - (390R on the schematic) for 8k2...
(Kat exits stage left and wanders off to correct the schematic...) My fault; when adding new components it's easier in 'Eagle' to copy one that's already there... sometimes I forget to change the value... Hope that slight change in value sorts out the overly-large sync pulses... Cheers, Kat Last edited by Kat Manton; 19th May 2006 at 10:52 pm. |
