Old 22nd Oct 2018, 12:14 pm   #1
Paul JD
Default GEC AC37 volume pot.
Hi, I am working on a GEC AC37 that needs a new volume pot (R3). The original pot is a 7k that also incorporates the mains switch, the closest I can find with a suitable switch attached and that will fit is a 10k. I was thinking it might make sense to change the value of R5 that is in parallel with the pot. Currently the pot is 7k with a 6.6k across it, with a 10k pot changing R5 to about 5k should keep the same overall parallel resistance? Does this make sense?
Paul
Paul JD is offline
Old 22nd Oct 2018, 1:03 pm   #2
Boater Sam
Default Re: GEC AC37 volume pot.
The 6.6K is not across the volume control.
A 10k pot as a direct replacement will be fine, shunt it with a 22k if you wish.
Boater Sam is offline
Old 22nd Oct 2018, 1:24 pm   #3
Paul JD
Thanks Sam, much appreciated. I was struggling to visualise what the 6.6k R5 was for but thinking about it again I guess it could be to safeguard against the pot going open circuit?
Paul JD is offline
Old 22nd Oct 2018, 4:37 pm   #4
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
Maybe I'm being pedantic, but isn't R3 technically an RF gain control, rather than a volume control, per se. Surely, whatever name it is given, R3 is-in effect-in parallel with r5 via the winding L2, assuming the 'bottom' end of R5 to be earthed, that is.
'LIVEWIRE?' is offline
Old 22nd Oct 2018, 6:20 pm   #5
Paul JD
Yes, the service sheet describes it as gain control which varies the grid bias and also acts as an aerial earth shunt.
Paul JD is offline
Old 22nd Oct 2018, 7:00 pm   #6
Boater Sam
It both increases the bias and lowers the sensitivity, quite common in old TRF sets.
