1st Jan 2020, 10:20 pm | #1 |
Shower element for dummy load
I replaced the electric shower on Christmas Day, nothing wrong with it you understand, been working fine for 35 years but it looked a bit tired and I couldn't think of a sensible present for SWMBO so I had bought an absolutely super new shower. Anyway, while putting the old one in the bin I thought to extract the heater bit for examination and found it has two sections which are used in ||el for a nominal 7kW.
The sections are 20Ω and 15Ω respectively, which means it can be used as a load at either 35Ω (VSWR < 1.2 at 50Ω) or 8.6Ω for audio. Prolonged high-power operation might require some water flow I don't anticipate any requirement for a QRO load, if anyone is looking for such an item
- Julian It's good here |
1st Jan 2020, 10:25 pm | #2 |
Re: Shower element for dummy load
For HF use I'd be worried that the capacitance between the inner heating-core and the outer metal sheath could mean it presented as something other than a purely resistive load.
2nd Jan 2020, 10:09 am | #3 |
Pure 35 Ohm resistive is not as good as 1.2:1 VSWR
Closer to 1.5:1 but with the inductance and capacitance present that is probably meaningless unless down at low frequencies. |
2nd Jan 2020, 11:00 am | #4 |
what make is the old shower unit
2nd Jan 2020, 11:21 am | #5 |
Sadia Heatrae. It originally had a touch switch but that failed and I replaced it with a very well insulated push switch
