1st Jan 2020, 7:56 pm | #21 |
Re: Nude EF50's Look Great
The RCA metal envelope valves/tubes:
http://www.rfcafe.com/references/rad...adio-craft.htm http://www.r-type.org/articles/art-018.htm Lawrence. |
1st Jan 2020, 8:11 pm | #22 |
Noticing mention of the Catkins in the article above, I gather that there was a HT-rectifier version of the "Catkin". Aieeee!!!
I really hope that the perforated-metal screen was well-attached, otherwise you could touch the rectifier anodes! |
1st Jan 2020, 8:51 pm | #23 |
Don't remember seeing a rectifier but there was certainly an output pentode MPT4 Catkin and that had no screening can the Anode was totally exposed
http://www.r-type.org/exhib/aab0043.htm these are a bit lethal I somewhere have a set with a set of Catkins I haven't come across it yet but I still have more than 100 sets to unpack Cheers Mike T
1st Jan 2020, 9:00 pm | #24 |
No Longer a Member
I think the EF50 has great historical significance to the UK. They are a limited resource to be preserved where possible. They outclassed their American contemporary , the 6AC7 which was a plain octal, and not as suited to Airborne use like a local. As pointed out, they supported the radio and Radar gear that won the war.
If these did get widespread audio use, eventually all the originals (of which there might seem plenty now) will get used up, then they get cloned but the clones will never be as good,not for RF applications anyway. When I first saw the EF50, over 50 years ago, I was "blown away" and my opinion of them and their significance in valve history has not changed since. It was one of the things that inspired me to build the Argus TV set. |
1st Jan 2020, 9:08 pm | #25 |
Hi Gents, there was a 3, EF50 set in an edition of PW back in the 50's/60's.
Ed |
1st Jan 2020, 9:31 pm | #26 |
I've posted these pictures before, but they seem relevant again.
This is an EF50 in my collection with a brass screening can, not the usual aluminium. I've never seen another one, and despite asking around for any opinions on 'why, when, who', nobody else has come up with any suggestions, so it remains a mystery oddity. |
1st Jan 2020, 9:36 pm | #27 |
This is part of a general problem. The audio business, driven by the twin principles that valves are best and only NOS are any good. will work its way through all period thermionic devices in existence that are capable of amplification or rectification.
As stocks of their preferred types get used up, prices will soar and people without bottomless pockets will go looking for any alternatives. There have been people looking for cheaper alternatives for a long time. New valves are in current production, but these are exclusively audio/guitar/rectifier types. That's where tho money is, but it's a dramatic reduction from the number of types of the past. If your interest is in radio or TV, you're left out in the cold. I have a few valve radios for which I've bought spares, and I have a small collection of valves from my teenage exploits, but that's it. On a matter of principle, I design no new equipment around valves. I'd rather leave period devices to keep period equipment going. This isn't an onerous limitation, because I allow myself to listen to music through transistors, and I even allow myself to enjoy it. Over the years I've fixed numerous Quad IIs and Leaks for people and I like the engineering in them, but I don't have one. I don't really need one. I remember de-canning a dead EF50 back in the sixties, admiring its ellegance and discovering that the evacuation pip is hidden in the spigot of the base... neat! David
1st Jan 2020, 9:41 pm | #28 | |
Using 'Wearite' coils, an EF50 RF amp followed by an EF50 infinite-impedance-detector was at one time the basis of my 'high quality local-station' medium-wave tuner, fixed-tuned to 247M Radio-1 and fed from a 60-foot-or-so longwire antenna. The lack of AGC to cope with fading was a nuisance as daytime moved into nighttime. |
1st Jan 2020, 10:27 pm | #29 |
Please, please, please, convince the audiophiles that that the route to Nirvana lies with the EF80! If these increase in price then I'm minted!
I was so upset that I cried all the way to the chip shop. |
1st Jan 2020, 10:29 pm | #30 | |
Cheers Mike T
1st Jan 2020, 11:25 pm | #31 |
Apparently, there were even a handful of mid '40s consumer radios that used the EF50 as an RF stage;
http://www.bushradio.co.uk/bushexport.html which seems a little odd- something like the EF39 would seem more appropriate from various angles- variable-mu as opposed to straight, the same International Octal valve socket as other valves on the same chassis, easing stock-holding and chassis-punching. Perhaps by this time EF50s were so plentiful as surplus that there was an element of "too cheap to resist" by some designers. Marconi's CR150 used a quad of EF50s in its front end with scaled AGC for the two RF amps, but that's understandable in a set that endeavoured to cover up to 60MHz, less easy to rationalise in a domestic-quality set with coverage to 22MHz or so. |
2nd Jan 2020, 1:28 am | #32 |
I suppose the only advantage of the audiophools getting interested in EF50s would be someone might start making the holders again?
2nd Jan 2020, 3:44 am | #33 | |
No Longer a Member
The EF50 socket is unique, it has very high tension claws that act over a very small surface area on the valve's pin. I doubt if the socket cloners could come close to getting the metallurgy right. Fortunately original ceramic and phenolic sockets are still available for the EF50. |
2nd Jan 2020, 3:50 am | #34 |
I remember having what looked like a PTFE socket for the EF50 back in the sixties.
2nd Jan 2020, 7:57 am | #35 |
No Longer a Member
Have a look at the EF50's in this article on my Argus TV. THe photos don't get the colour balance exactly right, but the EF50's are not quite fire engine red. They have just a faint tint of blue, so the red is fractionally magenta.
I searched to find ones with perfect original paint an the AM logo with the crown. If a valve like the EF50 doesn't inspire the will to build something, probably no valve would: http://worldphaco.com/uploads/ARGUS.pdf I have some EF50's that are fire engine red, labelled "Pinnacle" but the paint is slightly orange peel in its texture, and I think they were re-sprayed and re-labelled some time in the late 1950's of 1960's and they are in fact wartime valves. |
2nd Jan 2020, 1:54 pm | #36 | |
I gather that Pinnacle were a wholesale re-seller- possibly using the lorry-loads of plain silver VR91s/CV1091s that were swilling around. Maybe the feeling was that folk were more familiar with the Pro-Electron designation than the Services codes. |
2nd Jan 2020, 2:47 pm | #37 |
Yes, Pinnacle were one of the major rebranders/distributors - in the same vein as Bentley Acoustic Corporation, Haltron, Torvac, Zaerix, Trigon - they bought valves from wherever they could get them and slapped their own brand on them.
Sometimes this meant rebranded Government-surplus stocks, sometimes end-of-production-run stuff or 'not-quite-good-enough-for-the-military' stuff from mainstream manufacturers, sometimes imports from Eastern Europe communist-states desperate to sell anything in return for Western currency. Personally, I doubt any EF50s were made after WWII ! The demand for them fell away quickly once the likes of the EF91 and EF80 appeared on the TV scene, and there must have been loads of EF50s in Government warehouses. to maintain supply. |
2nd Jan 2020, 2:50 pm | #38 |
The American all metal valves are incredibly reliable. J.
2nd Jan 2020, 3:31 pm | #39 | |
Cheers. SimonT.
The honesty of imperfection.......... |
2nd Jan 2020, 3:46 pm | #40 |
Dad built a ViewMaster as and when the plans came out. He used to extol the virtues of "Sylvanian Red" EF50s but I don't know if he ever got round to using them. My guess is there's no difference between those and their contemporaries but does anyone know? And what company/country/province is "Sylvania"?
Graham
Half my stuff is junk - trouble is, I don't know which half! |
