27th Sep 2015, 8:58 pm | #1 |
Minimitter Car Radio Converter
Folks, I've already scrolled through the threads shown on "Search", but nothing on this wee gem. Those other threads are on M/M's range of larger Tx's & Rx's.
Mobile-wise, this we converter is connected to a car radio set at 1.5MHz, and enables the user to receive 5 amateur bands :- 3.5, 7, 14, 21, & 28 MHz. Does anyone have a circuit diagram &/or manual please? It'll work on Mains also. Regards, David |
27th Sep 2015, 9:07 pm | #2 |
Re: Minimitter Car Radio Converter
Using a car-radio mobile as the "IF" stage and audio-demodulator was kinda-commonplace back in the 1950s and 1960s when AM was still being used a lot.
[And again in the late-70s/early-80s when US 23-channel AM CB rigs were imported and people wanted to tune in to CB on their car radios] Does your Minimitter converter have a crystal or is it free-tuned? What voltages does it need? What valvs are in there?? From the mid-50s onwards, there were plenty of radios that used "12-volt HT" valves [ECH83/EF97/EF98 etc] which were actually specially-selected versions of the likes of the 'mains HT' ECH81 etc that were chosen because they were at the upper end of the performance-spec for their class]. Last edited by G6Tanuki; 27th Sep 2015 at 9:13 pm. |
27th Sep 2015, 9:34 pm | #3 |
Apologies, but I don't know where this info came from:-
Regards Pete |
27th Sep 2015, 9:54 pm | #4 |
RSGB I think.I seem to remember adverts for these in the 60,s.
27th Sep 2015, 10:24 pm | #5 |
Only just been given this wee set. Great weather this weekend, so outside jobs take priority. But it wont last, so thought I'd get some gen in preparation for a rainy day in the workshop.
I'll open it up & delve inside as soon as I can. Many thanks for replies so far. Just wondering - did any particular car manufacturer advertise these sets as an optional radio feature? Regards, David |
27th Sep 2015, 10:38 pm | #6 |
There are other threads David. Add Alf [Forum member] to Minimitter search via here or external google page. Alf passed on his set to me as mentioned in the Minimitter History thread of 7/10/13. It is a bit of a struggle to extract info
Dave W |
27th Sep 2015, 11:25 pm | #7 |
Dave, Alf's thread mentioned an MR37 with an 8 way wave change switch. But this set has no model no. & only a 5 way w/c switch. I was assuming his was a much bigger set.
The Minimitter Company's range of equipment is completely new to me, I must admit. But I intend to learn. Regards, David |
28th Sep 2015, 12:47 pm | #8 |
Hi David. Yes it was all a bit confusing at the time and remains so. I had presumed that the set I collected from him [eventually] was the same one he mentioned but I hadn't picked up the discrepancy re 8 or 5 wavebands.
The RSGB page that Pete put up here [he may have got it from that Minimitter History thread] seems to definetly ID your set [and mine] as being an M37 with 5 Bands[listed] but info is scarce and obscure. The reviewer clearly thinks it's an M37! I'll check it all out again when I get back to my example in the North, in the near future. I see that Alf was on the Forum in August so, as you are opening up your Minimitter, it might be an idea to send a pm and see if you can clear up the mystery. You might want to treat your practical investigation as vital research Dave W |
28th Sep 2015, 4:45 pm | #9 |
Right enough, Dave - it would seem,(according to the pdf kindly supplied by Pete), that this set is the top LH half of what W H Allen describes as a MR37 Communications Receiver in his article in the RSGB Bulletin of Feb.1958.
In 1958, as a 13 year old, my head was completely empty of any knowledge of radio technology at the time. I did acquire an ancient Bakelite radio the following year, and I always remember the o/p valve being a PM24B which glowed like a light bulb. Perhaps that initial inquisitiveness heralded my entry into the RAF in 1961 as a Boy Entrant trainee Air Wireless Mechanic. Now my inquisitiveness is telling me that maybe I should seek out the other two sub assemblies which make up the complete MR37. Rather than consider it as an addition to a car radio(that's what I was told it was), although it looks as though that is what someone has used it as at some stage. Regards, David PS. I hope this isn't going to turn out as a time-consuming quest for info on a long defunct company - like BEME, Rees-Mace, Coastal Radio, etc. |
28th Sep 2015, 10:05 pm | #10 |
Probaly but that's what we are here for. I'm not even that technical
Dave |
2nd Oct 2015, 10:57 pm | #11 |
Just had a shufti inside - two valves :- 6BY7 & a 6AJ8.
Just wondering, are there any older amateur guys out there who, back in the 50's & 60's, worked a complete "Minimitter" rig ? What sort of range & reception did it have ? Regards, David |
3rd Oct 2015, 7:39 pm | #12 |
David,
Bob/G6AVI was running his usual Minimitter TX on the VMARS 3615 kHz AM net this morning, maybe he can help? 73 Roger |
