18th May 2020, 8:04 pm | #281 |
Re: Fixing a GEC BT 302 Television
This type of capacitor (not an electrolytic type) can be fitted either way round.
As already suggested, fit them so that the value can be seen. |
18th May 2020, 8:12 pm | #282 |
Ok John thanks again sorry I get bit confused,
18th May 2020, 8:22 pm | #283 |
First ones in
18th May 2020, 8:40 pm | #284 |
That's the correct way Daz.
Just for future reference, R98 is the cathode bias resistor and looks a bit cooked. It's rough condition will not prevent the frame stage from working so that can be dealt with later. It's value is 300 ohms which is a non standard value. I fitted a 330 ohm in mine and as you can see, it is OK. Just carry on with the cap replacements but take care! John. |
18th May 2020, 9:30 pm | #285 |
Here we are so far
18th May 2020, 9:36 pm | #286 |
It would help if the values were visible or perhaps in focus. Then members would know if you've fitted the right value caps in the right places. Could save a lot of bother later on.
18th May 2020, 9:44 pm | #287 |
Ok ill zoom in
18th May 2020, 9:46 pm | #288 |
The 2 top ones one are 0.1 uf
18th May 2020, 9:50 pm | #289 |
and the other 2 a 0.0047
18th May 2020, 10:00 pm | #290 |
One of the campictors is 0.02. I have a 0.22, is this one correct
18th May 2020, 10:02 pm | #291 |
You'll need to specify units uF? nF?
18th May 2020, 10:05 pm | #292 |
Oh sorry UF
18th May 2020, 10:08 pm | #293 |
Going back to post #211, C115 is 0.02uF or 20nF. Replacement would be 0.022uF or 22nF.
You cannot replace this with 0.22uF.
18th May 2020, 11:34 pm | #294 |
Job done apart from one comp, C115, I only have 2 comps left 0.47 uf
0.22 uf |
18th May 2020, 11:41 pm | #295 |
I don't see why you have either of those values. See post #211.
18th May 2020, 11:51 pm | #296 |
Everything else is correct, one missing.
18th May 2020, 11:58 pm | #297 |
What we have so far
19th May 2020, 12:12 am | #298 |
Gonna get some kip night all
19th May 2020, 12:45 am | #299 |
I thought it was suggested the components were put in with the value showing
I bet that car doesn't have a suppressor. |
19th May 2020, 7:37 am | #300 |
Three times I think!
