Reply
Old 24th Apr 2024, 10:34 am   #1
Ian - G4JQT
Ian - G4JQT's Avatar
Default 812A triode on CT160 tester
I know a local watch and clock repairer who has a L&R Vira-Matic ultrasonic cleaner which uses an 812A triode valve. The machine is playing up and the first thing to check is this valve.
I don't have my CT160 or the valve-settings book to hand, but can anyone tell me if the CT160 is able to test this valve before he gives it to me?
Thank you.
Ian - G4JQT is offline   Reply With Quote
Old 24th Apr 2024, 12:40 pm   #2
Chrispy57
Default Re: 812A triode on CT160 tester
Hi Ian - the 812A is not listed in the AVO data book (23rd Edition) so it looks like a "no". The CV equivalent of the 812 CV2661 is also absent.
Chris
Chrispy57 is offline   Reply With Quote
Old 24th Apr 2024, 12:42 pm   #3
Ian - G4JQT
Thanks Chris. Looks like that saves me a job!
Old 24th Apr 2024, 1:01 pm   #4
Craig Sawyers
Craig Sawyers's Avatar
Looking at the characteristics, it is a bit of a beast. Operating with grid either positive or negative, and a VAmax of 1500V and substantial current, the AVO valve testers can only access a small corner of the characteristics.
http://www.r-type.org/pdfs/812a.pdf
Which is why I guess it is not in the AVO data books.
Craig
Doomed for a certain term to walk the night
Craig Sawyers is online now   Reply With Quote
Old 24th Apr 2024, 1:52 pm   #5
Cruisin Marine
Data here
http://www.r-type.org/exhib/aaa0548.htm
Mote that it takes 4 amps heater current, so likely to damage your valve tester.
"Behind every crowd, there's a silver Moonshine"
Cruisin Marine is offline   Reply With Quote
Old 24th Apr 2024, 8:33 pm   #6
Alan Bain
The circuit is I think the one attached. Tapped inductor oscillator, but quite a beast 1.4kV HT.
Name:	LR Ultrasonic Driver Circuit Old.jpg
Alan Bain is offline   Reply With Quote
Old 28th Apr 2024, 8:53 am   #7
Sean Williams
Sean Williams's Avatar
From memory, John at Colomor used to test transmitting type valves on the VCM163 with an external heater transformer.
You wont get any meaningful readings, but the 811 triode is similar in specification.
812a arent exactly audiophool territory, so check by substitution isnt going to be an expensive option
Sean Williams is offline   Reply With Quote
Old 28th Apr 2024, 10:56 am   #8
David Simpson
Ian, simple answer is definitely NO. The filament current at 4A is twice what a CT160 could handle. CT160's, with their single all purpose mains transformer, already struggle at 2A. Likewise, MK3's, MK4's, & 163's, even with separate T/F's.
You would need a 12V car battery, with a hefty dropper, to supply 6.3V at 4A, or a big thumper of a DC LV PSU. Even then, to get the high slope triode to work on even the bottom end of the Ia/Vg Curve, AVO VCM's would need to work at max Va & Vg. Also, CT160's have a propensity to jump into PO mode.
Only choice - build a temp DC testing rig, utilising a UX4 valve holder.
I've done this with STC4212D's & their kin. If you have a shot at it - be extremely careful.
Regards, David
David Simpson is offline   Reply With Quote
Reply
