Reply
Old 19th Apr 2024, 6:35 pm   #1
trh01uk
trh01uk's Avatar
Default Transformer leaking oil - fix it or bin it?
Folks,
I have a rather nice HT/LT transformer which has started to weep oil from around a terminal.
Anyone tried fixing this problem? If so, did you succeed, and how did you do it?
Is the oil dangerous by the way? It was made by Willesden Transformer Co Ltd if that's relevant.
Richard
trh01uk is online now   Reply With Quote
Old 19th Apr 2024, 7:07 pm   #2
Craig Sawyers
Craig Sawyers's Avatar
Default Re: Transformer leaking oil - fix it or bin it?
Could be mineral oil, in which case no problem. Or it could be PCB (poly chlorinated biphenyls) which is real nasty.
You have no way of knowing.
I had a transformer do that in a Racal SSB adaptor. Where it has pooled in the bottom of the chassis, it had gone to tarry goo, suggesting it was mineral oil oxidising in the air.
But you have no way of knowing what your TX is leaking, Richard. Safer to dispose of alas.
Craig
Doomed for a certain term to walk the night
Craig Sawyers is offline   Reply With Quote
Old 19th Apr 2024, 7:30 pm   #3
Cruisin Marine
I have successfully used Araldite in the past, but make sure you avoid contact with the oil, in case it is the dreaded PCB.
Make sure the tfmr is not getting hot before any serious work. A shorted turn can cause this.
"Behind every crowd, there's a silver Moonshine"
Cruisin Marine is offline   Reply With Quote
Old 19th Apr 2024, 8:23 pm   #4
kalee20
There are tests for PCB's, basically using metallic sodium with a suitable catalyst to rip off the chlorine atoms, and then doing a simple test for chlorides. An internet search may find a lab that'll do it, but it may cost...
If you suspect it contains PCB's you're stuffed either way - you can't dispose of in normal waste or WEEE - it's hazardous waste.
I actually think it's more likely not to be PCB and just be refined mineral oil. But there's still a significant chance that it could be - they were the wonder chemicals of the time and ticked a lot of boxes
kalee20 is offline   Reply With Quote
Old 19th Apr 2024, 8:56 pm   #5
trh01uk
trh01uk's Avatar
Thanks everyone for that guidance. I rather feared we might be talking about PCBs here. I would rather not take the risk. I will try and dispose of it safely.
Richard
Reply
