Reply
Old 14th Apr 2024, 5:10 pm   #1
60 oldjohn
Default 10k pot in wobulator?
VR3 in this wobulator https://www.worldradiohistory.com/UK...RC-1960-10.pdf is 10K with mains switch. I an certain it would be Linear. I have 20k Lin would a 10K across the track be ok? or I have a 10K log would it work with maybe 4.7K end of track to slider? I have used this arrangement in audio but this is a bit different. The pots on the net are all short shafts, I need 22mm x 6.3mm and there is not enough room to get a joiner in. So hoping I can make something work that I have here without having to wait for postage.
Please type in "21" for page number and to the right of this is a rotation tag as the image is on it side.
John.
My favourite text message "I'll be there in five minutes, if not read again"
60 oldjohn is offline   Reply With Quote
Old 14th Apr 2024, 9:02 pm   #2
John_BS
John_BS's Avatar
Default Re: 10k pot in wobulator?
20k should be fine: parallel another 20k fixed across the track if you want to be pedantic!
John
John_BS is offline   Reply With Quote
Old 15th Apr 2024, 10:10 am   #3
60 oldjohn
John
Oops, I meant add a 20k across the track. thank you for your reply, I will do that.
John.
Old 15th Apr 2024, 1:07 pm   #4
Chrispy57
Hi John, apologies for possibly throwing a couple of spanners into the works;
but I noticed that the parts list in your linked magazine specifically mentions that the other two potentiometers, R1 and R2, are linear - perhaps implying that R3 is not linear?
Also, you say that you already have a 10k log potentiometer - so why would that need an additional 4.7k resistor if the original is also 10k?
I'm hopeful that you may already have the solution to your problem at hand - is it worth trying?
Chris
Chrispy57 is offline   Reply With Quote
Reply
