Old 11th Nov 2019, 11:59 pm   #1
goughy57
Default Sony HP-511. Belt size needed.
hi
i have a sony hp-511a on the bench. the drive belt is in bits, the service manual gives no indication of the size. anyone have the dimensions please. ?
goughy57 is offline
Old 12th Nov 2019, 12:28 am   #2
ajgriff
ajgriff's Avatar
Default Re: belt size needed
I suspect you'll have to do some measuring. Cotton tied around the pulleys has worked for me in the past. There was a thread recently about measuring belts but I can't immediately locate it.
Alan
ajgriff is offline
Old 12th Nov 2019, 12:41 am   #3
Piccy2valve
https://www.amazon.co.uk/TURNTABLE-D.../dp/B00T7Q6HJG
Piccy2valve is offline
Old 12th Nov 2019, 5:20 am   #4
ajgriff
ajgriff's Avatar
Problem solved. Well done!
Alan
ajgriff is offline
Old 14th Nov 2019, 11:18 pm   #5
goughy57
Default Re: Sony HP-511. Belt size needed.
thanks to all for the help. managed to find the correct size dimensions for the belt for the sony hp-511a. for the record its 195mm x 6mm. the 6mm is important otherwise the speed change won't operate correctly.
goughy57 is offline
