26th Jun 2014, 7:06 am | #21 |
Re: A few obvious questions about Mullard 3 3 building.
As you already have an EZ80, you may as well stick with valve rectification. Using a bridge rectifier will make your project a 2- 3, not a 3-3. Then why not get rid of the EF86 and use a transistor instead? Joking of course.
The point I'm trying to make is that as the 3-3 is pretty perfect as is, why muck about with it? Silicon rectification also has its place of course. You can use a bridge rectifier in one package where you connect your AC from your mains transformer to the wavy line symbols (AC), your HT from the + symbol ground to - on the package. Easy. Or you can use 1N1007 diodes connected in a bridge configuration or other. I suggest you look up rectification. Valve Wizard is a good site to check out for this and other subjects. Andy.
27th Jun 2014, 1:58 pm | #22 |
Oh, Well I went with the one stated in the r-type article.
So I went in search on adding a fuse to a radiogram I found, but I soon found out that instead of a fuse it uses lamps - by what I have learnt on heating/powering valves I assume the lamps are also 6.3V. Could I power the bulbs using a 9v battery with a resistor to lower the voltage? If so would a resistor of 27ohms be right? I have the "Electronics for Dummie"s book, where I got the ohms law equation (rather annoying I hate maths but it was simple). So while searching I came across this site Last edited by Mike Phelan; 27th Jun 2014 at 5:01 pm. Reason: Readability. |
27th Jun 2014, 2:41 pm | #23 | |||
Cheers, GJ
http://www.ampregen.com |
27th Jun 2014, 3:21 pm | #24 |
The bulbs are in series I think. See image.
I was just going to see if it would work. |
27th Jun 2014, 3:42 pm | #25 |
Nope, that's 'parallel' not 'series'.
In what sense are those lamps "instead of a fuse" ? Cheers, GJ
27th Jun 2014, 3:55 pm | #26 | ||
SO I was mis interpreting it? (taken from http://vintage-radio.com/repair-rest...ly-stages.html |
27th Jun 2014, 5:07 pm | #27 |
The first quote is headed Dial Lamps in AC/DC sets.
The circuit you showed in post #24 has a mains transformer in it, which means it is not an AC/DC set. So none of the stuff in the first quote applies. I'm still not sure where you've got the idea that the lamps are "instead of a fuse" from. Neither of your bits of text mentions lamps as fuses. They sometimes are used as fuses. But only sometimes. Cheers, GJ
27th Jun 2014, 5:11 pm | #28 |
so i have mis-understood the concept,
27th Jun 2014, 6:18 pm | #29 |
Thread closed pending moderator discussions.
