3rd Dec 2019, 4:59 pm | #1 |
BSR SX6M. What Stylus?
Hi Everyone,
What is the best stylus to use for my BSR SX6M? I'm only going to play 45's and 33's. What types fit the BSR SX6M. ATB, Vin
Vin |
3rd Dec 2019, 6:09 pm | #2 |
Re: BSR SX6M What Stylus
ST 14 should be fine and readily available
4th Dec 2019, 9:12 am | #3 |
If you are only going to play microgoove records, then be sure to get the LPS/LPS double sided type.
Edward. |
5th Dec 2019, 11:50 am | #4 |
check the ceramic cartridge data sticky. ST15 probably the best here.
Regards, Ben. |
6th Dec 2019, 4:03 pm | #5 |
Thanks for the Advice all.
Vin |
11th Dec 2019, 5:09 pm | #6 |
One of the pins broke (due to corrosion) whilst disconnecting for cleaning may try to fix but are there any other cartridges that fit the mounts for the SX6M?
Vin |
12th Dec 2019, 6:55 pm | #7 |
Re: BSR SX6M. What Stylus?
One channel doesn’t work Anyone got a spare cartridge for purchase?
Vin |
13th Dec 2019, 12:56 pm | #8 |
Is it a Stereo cartridge (4 pin) you need - or just a stereo-compatible type (2 pin)? If you don't know, what type of player are you using?
Edward. |
13th Dec 2019, 1:38 pm | #9 |
The BSR SX6M is a stereo cartridge with four pins.
13th Dec 2019, 1:45 pm | #10 |
Yes, but is a true stereo cartridge actually required for Vin's record player?
Nick |
13th Dec 2019, 1:48 pm | #11 |
Does not post #7 supply the answer?
13th Dec 2019, 5:01 pm | #12 | |
An sx5m, (or x5m for mono - what player is this going into?), but they are hard to find and expensive. I would go for an SC12 instead.
Regards, Ben. |
15th Dec 2019, 3:52 am | #13 |
SC5M and SC5H ceramic cartridges should fit the SX6M mount, but the output of these is a lot lower. I could probably fix the SX6M for you, I've got spare parts, but I'm a long way away.
The Waves That Rule Britannia Last edited by suebutcher; 15th Dec 2019 at 4:07 am. |
16th Dec 2019, 6:12 pm | #14 |
Are you sure one channel on the cart does not work? or could it be the player that has a channel down?
If it's confirmed as the cart then I could fix it for price of postage. Gaz. |
16th Dec 2019, 6:59 pm | #15 |
Please bear in mind that one of the pins has broken.
