24th Oct 2019, 4:35 am | #1 |
Revox A77 Tape loose
I recently replaced components on the speed control board which fixed the speed control problem I was having.
However now the take-up (right hand) reel is not maintaining tension on the tape. Any clues? ken |
24th Oct 2019, 12:22 pm | #2 |
Re: Revox A77 Tape loose
I think you should also replace parts on the relay board
Jack Marotick |
24th Oct 2019, 2:57 pm | #3 |
Is the rewind motor providing back tension in play mode?
Lawrence. |
24th Oct 2019, 9:47 pm | #4 |
Check that the MOTORS OFF button is not pushed in.
Check continuity across the switch contacts |
29th Oct 2019, 4:28 am | #5 |
Many thanks for all of your replies.
Here is what is happening in each mode:- Play Take up spool not keeping tension on the tape. Also it only works whilst the button is pressed (i.e not latching) Rewind Working O.K. but it only works whilst the button is pressed (i.e not latching) Fast Forward Rewinds at what appears to be 'Play' speed. Again it only works whilst the button is pressed (i.e not latching) ken |
29th Oct 2019, 9:37 am | #6 |
Remote plug loose, or wire disconnected there?
Regards, Ben. |
30th Oct 2019, 12:31 am | #7 |
As Ben says, check that the remote dummy plug is fitted. if it is check the End Of Tape sensor and the two transistors connected to it.
I also suggest you replace the two 4.3uF reel motor run capacitors and the 3.5uF capstan motor run capacitor. You can get them from Revox online and/or Nagravox |
30th Oct 2019, 6:41 am | #8 |
Thanks again everybody
I must admit I didn't realise that the dummy plug was part of the circuitry so putting that back fixed the latching problem. Thanks. I will purchase the three capacitors as suggested Michael and let you know how that goes. ken |
