15th Mar 2014, 9:22 pm | #1 |
Mystery Candlestick (Conversation Pieces?)
Hello,
I hummed and hawed about purchasing this as it’s very brassy for a candlestick but my want for a candlestick (and the fact it was relatively cheap) won out in the end. I had a bit of a chuckle when I tested it and it’s tone ringer reminded me of a TRIMphone. Having a search on the forums suggests this might be from the Conversation Pieces range? And could somebody please tell me how to get into the base as I would like to disconnect the tone ringer and use it with a bell. Apologies for the mobile pictures. Cheers, Jim
"And what on earth are you going to do with that?" |
15th Mar 2014, 9:35 pm | #2 |
Re: Mystery Candlestick (Conversation Pieces?)
Given that there is a label on the base reading "Removal of this label would [result in?] forfeit of the warranty", I would expect that there is some sort of retaining screw behind it.
If you do succeed in opening the base - after all the warranty is not going to be valid anyway - it would be interesting to see what (modern) circuitry is hidden therein. I wonder whether there would be sufficient space to fit one of those miniature mechanical ringers inside.
15th Mar 2014, 9:45 pm | #3 |
Hadn't thought of that, Dave! But it turns out there is no screw behind the warranty label.
I have had the dial off (it's fixed to the base with a single screw) and inside there is a small(ish) PCB. The PCB is secured to the base via the screws in the rubber feet. Regards, Jim
15th Mar 2014, 9:51 pm | #4 |
A bit of digging threw up this thread from 2008 and this page from Bob Freshwater's Telephone File on these reproduction telephones. Mention is made of Telephone Lines of Cheltenham who may have had a connection with the now defunct Conversation Pieces Ltd.
15th Mar 2014, 9:51 pm | #5 |
What about that central nut, Jim?
15th Mar 2014, 9:58 pm | #6 |
Dave: Those were the links I also found.
Nick: The central nut retains the mouthpiece. I have tried removing the nut and levering the base off but it didn't budge and I didn't want to force and damage anything. Regards, Jim
15th Mar 2014, 10:03 pm | #7 |
With both the nut and the dial removed, can you gain access to any position on the base where you can apply pressure from the inside rather than levering from the outside?
15th Mar 2014, 10:09 pm | #8 |
That thought did cross my mind; from my feeble attempts with just my fingers the base was as stubborn as it was with the levering. I may attempt it again but with something I can apply a bit more force with.
Regards, Jim
15th Mar 2014, 11:12 pm | #9 |
I tried some more gentle levering, as the base seems to suggest this is how it's removed, what with the cutout in it.
Success! Attached is a photo of the PCB. Unfortunately, the disabling of the tone ringer is more destructive than I hoped as it's hard-wired to the board. Cheers, Jim
16th Mar 2014, 5:51 am | #10 |
Is that IC in there an SGS-Thomson LS285, by any chance? Basically, a silicon replacement for the induction coil. Although they were still using a mechanical dial .....
You might well be able to silence the tone ringer simply by disconnecting pin 3 of the line cord (blue, if coded red-blue-green-white). Otherwise, it should still only require unsoldering -- or cutting -- one wire. Any chance of a picture of the wiring side of the PCB, and a picture of the component side with wires out of the way and/or an explanation of what goes where?
16th Mar 2014, 10:19 am | #11 |
I may be wrong, but I can only see two leads coming from what I assume is the line cord - oddly coloured white and blue. Is there a red lead hidden?
16th Mar 2014, 11:04 am | #12 |
Dave, you may be mistaking the wire pair that goes to the receiver, which in this phone is white and blue, as the line cord.
From memory, the red, blue, green and white wires from the top connected to the top of the board is the line cord. The white and blue pair also connected to the top of the board go to the receiver. The pink, slate, orange and blue group of wires goes to the dial, and the brown pair goes up the stem to the hook switch and transmitter. If I have time this evening I'll take some more photos and confirm the wiring. Regards, Jim
16th Mar 2014, 2:12 pm | #13 |
Thanks for the clarification - that makes more sense. I wasn't sure which cord was which. There may, however, be a problem with following the advice given concerning disconnecting the blue wire from the line cord. Doesn't this normally feed the receiver as well as the ringer? Although there's no harm in trying if it is simply a matter of unhooking a connector.
16th Mar 2014, 10:43 pm | #14 |
Right, here are some photographs that are hopefully a bit clearer.
The connections are as follows: Top Green - Line cord Top row Blue - Reciever White - Reciever Red - Line cord Blue - Line cord White - Line cord Left colloumn Blue - Dial Slate and pink - Dial Orange - Dial Centre Pink Slate Orange Blue All go up stem Bottom brown x2 up stem. The IC is marked SGS LS285AB 88427H Regards, Jim
17th Mar 2014, 10:33 am | #15 |
Is the ringer just a piezoelectric sounder with no inbuilt drive electronics, or does it contain its own PCB and an IC?
I suspect the latter, otherwise there would be a driver IC on the main PCB, rather like with the Statesman range of phones. If that's the case, then maybe all you need to do is disconnect one of the wires from it. N. |
17th Mar 2014, 3:42 pm | #16 |
Well, according to the second picture, everything can be disconnected from the PCB. So what happens if you connect everything except the blue wire of the line cord?
17th Mar 2014, 11:47 pm | #17 |
Nick, I would agree with you.
I can confirm that disconnecting the blue wire of the line cord silences the tone ringer. However, on another note, upon connecting the phone to my PBX (a BT 2+8) I have found that the tone ringer whistles when on hook and there is no dial tone off hook, just silence until the timeout tone when the phone is not connected via an ADSL filter. Regards, Jim
19th Mar 2014, 12:43 am | #18 |
I had one of these many moons ago, the phone worked perfectly except the tone ringer, I ended up replacing the bridge rectifier, you could just cut a leg on the BR? Although saying that there appear to be two on this phone, and i dont remember the Conversation pieces one i had having two. And i would want to be sure that the BR isnt feeding another part of the circuit so you would have to trace it through to the
