29th Sep 2018, 8:42 pm | #21 |
Re: Coaxial aerial feeder question
Here's the coax and aerial plug from a 1937 Marconiphone television, working at the outlandishly high frequency of 45 MHz. I'd love to learn more about this connector, by the way.
Steve |
29th Sep 2018, 11:39 pm | #22 |
Concentric plugs of essentially the same configuration (but presumably bigger) for use with conventional flex were available in the Edwardian era as alternatives to the more common range of 2-pin plugs where a polarized connector was required: the attached scan is from the GEC catalogue for 1910-11. A plug of essentially the same configuration is used on the charger of my wife's electric bike.
30th Sep 2018, 1:30 am | #23 |
Coaxial connectors are also used in the bases of jug kettles.
30th Sep 2018, 2:53 am | #24 | |
inside, but had a non-functional unoriginal coax connecter installed on the back. I replaced it with a modern US standard one. Most interesting tidbit: the coax insulation was gutta-percha! |
30th Sep 2018, 6:48 am | #25 |
That Edwardian advert is most fascinating because it gives the weights in kilos. I wonder why it does that (esp as no dimensions are given in mm)?
David |
30th Sep 2018, 11:50 am | #26 | |
Al. |
30th Sep 2018, 5:58 pm | #27 |
Re: post 25.
Might be so that a buyer could calculate postage costs. Al. |
1st Oct 2018, 2:37 pm | #28 |
I assume that metric dimensions were provided with export in mind. I only have two of the four volumes of that catalogue, and both UK and Metric dimensions are quoted for pretty well every product. The parts I have do not include anything about general conditions such as shipping for export. I seem to recall reading that the Indian railways used the metric, not imperial, units for calculating freight shipping charges from an early date, given the existence of so many local weights and measures.
I note that it does list "American Edison Screw lampholders", with the caption "These lampholders are specially adapted for use in Canada, the South American states, and other Countries where the Edison screw thread is universal", so export to countries using the metric system was clearly contemplated. (The American version was externally different from the UK version, lacking the UK's ceramic skirt, and seems to have been provided with clamping grub screws to prevent accidental dismantling). |
1st Oct 2018, 2:55 pm | #29 |
Aye well thats my query...only metric weight was given, not dimensions.
Anyway, it was a long time ago... |
