Old 15th Dec 2018, 12:04 am   #1
Default Restoration AVO 40
Avo 40 to be restored, need help.
The movement i think was changed in 1977.
As i found it:
ID:	174621   Click image for larger version
ID:	174622   Click image for larger version
ID:	174623   Click image for larger version
ID:	174624   Click image for larger version
Old 15th Dec 2018, 12:05 am   #2
Default Re: Avo model 40 and model 7 movement
One more photo
Old 15th Dec 2018, 12:38 am   #3
Firstly i was thinking in taken it for parts, specially the movement to my AVO 7, but after testing it, i think it is worth to be restored.
That movement as i said i think is a replacement, and does not have the overload protection system, so, i do not want to put in my AVO 7.
Also i think that if i finally decide to restore it, i will need the correct movement.
Moderator: Could you change the title of the thread to: Restoration AVO 40?
Old 15th Dec 2018, 11:51 am   #4
The Philpott
The Philpott's Avatar
The scale-plate is Model 8 Mk II or III type, so if the movement is also Model 8 it is not compatible with any Model 7 or 40 anyway (but worth keeping as a spare)
Did you manage to get the spare Model 7 movement off ebay?
Dave
The Philpott is offline
Old 15th Dec 2018, 12:04 pm   #5
Yes, I bought it, but the seller did not send it to Canary Islands, do not know why, so I tell him to send it to my mother in law house, in the mainland.
After Christmas I will receive it. With that and my original plate, I can finish model 7
Now I need help with this AVO 40 it seems to be a coil missing on the left hand, there are couple of wires there and a few new wires bad soldered in the variable resistance that I eliminate.
So I need electrical diagram of this Avo 40 and a original movement.
At Richards page I found a similar Avo 40, but not the same circuit.
Thanks
Old 15th Dec 2018, 2:09 pm   #6
After removing the incorrect movement and remove a couple of non original and very bad soldered wires, the aspect is this. (See photos)
ID:	174648   Click image for larger version
ID:	174649   Click image for larger version
ID:	174650   Click image for larger version
ID:	174651   Click image for larger version
Old 15th Dec 2018, 3:57 pm   #7
Default Re: Restoration AVO 40
I drawn 2 circles on the wires that i think goes into a missing coil (i do not have the electrical diagram)
Old 15th Dec 2018, 5:54 pm   #8
Superscope
Hi Aitor,
Schematic for a Model 40 Mk II attached.
I assume it's a Mk II looking at the construction.
It looks like the Coil you are looking for actually resides on the Meter Movement Frame itself.
There are Two Coils (Bobins), one either side of the movement. See Photo.
One is the Swamp Resistance for the Meter and the other is the Divide by Two Shunt Resistance.
Off hand, I don't know which one is on the Left or Right side.
I think this is what you are looking for.
Ian
ID:	174673   Click image for larger version
ID:	174674   Click image for larger version
Superscope is offline
Old 15th Dec 2018, 6:15 pm   #9
Thanks very much, the photos of the inside that you have loaded correspond to my model, but in RichardĀ“s page, i understand that the AVO 40 with the arrows in the Knobs are MK1, and also he says that the same panel is used for both models (mk1 and mk2) without MK marks, but with the differences of the arrows.
So, mine has the arrows and is marked in the front panel "model 40" so it should be MK1, but inside it looks very is as the photos you posted, so i do not know exactly which model is it.
I attached photos of the front panel.
Also, in SuperscopeĀ“s first photo i can see the original shunt, that has been substitute for 2 resistances in mine (first photo is mine, second photo is the one Superscope load before)
Thanks very much for the schematic, just waiting to confirm which MK is this AVO 40
ID:	174676   Click image for larger version
ID:	174677   Click image for larger version
ID:	174678   Click image for larger version
ID:	174679   Click image for larger version
Old 15th Dec 2018, 8:40 pm   #10
Superscope
The Front Panel is definitely a Mk I
So I think your Meter is simply a later Mk I.
Very unlikely anybody rebuilt a Mk II interior on a Mk I Front Panel due to the amount of work involved.
So if AVO called it a Mk I, then it's a Mk I, just has the later style Movement and Interior.
I have no idea when the change in Movement happened on the Model 40's, but earlier Mk I's have a very different interior to the one in your Meter.
I'm guessing that your Meter Dates from sometime before 1956
Ian
Old 15th Dec 2018, 8:54 pm   #11
Thanks!!
Could you load a photo of more detail of the bobin at the left hand side?, i am in a doubt about the connection of those wires involved.
Aitor
Old 15th Dec 2018, 8:59 pm   #12
I see that the plastic "P" button is broken, do not know how difficult could be to get a new one, i did not see anyone on the internet
Old 16th Dec 2018, 1:11 pm   #13
Today i repaint a little bit the knobs, they are very worn out nut the result is acceptable!
Old 20th Dec 2018, 8:50 pm   #14
Also I am waiting to receive this AVO 40mkII to be restored as well, it has a bakelite case, i think that is correct.
No inside photos yet
ID:	174994   Click image for larger version
ID:	174995   Click image for larger version
Old 29th Dec 2018, 12:11 am   #15
As i said in the survey thread, this AVO was made in 1952, so the label on the right hand side and probably the case and instructions plate are from another Avo as i was told.
I think that my Avo 40 mk2 from 1957 should have metal case. Doesn’t it?
Old 29th Dec 2018, 12:14 pm   #16
Hello. Can anybody confirm if the Avo 40 mk2 used a metal battery cover or the Bakelite one with the 2 sticks probes and the “mysterious” probe or even used both?
Old 29th Dec 2018, 12:46 pm   #17
The Philpott
Mine has the aluminium cover, i believe it is original. This Model 40 lacks a serial number on the scale plate but SR22568 is hand engraved into the front on the meter.
(Sometimes a bakelite battery cover leaves slight marks on the inside of the leather strap where the edges have chafed.)
Dave
Old 29th Dec 2018, 1:10 pm   #18
I have seen the AVO40 mk2 with aluminion case and both battery cover so I am not sure if both were available in the 50’s
Old 29th Dec 2018, 2:43 pm   #19
Here is the AVO40 mk2 fully working. I cleaned the front panel, repair the smallest shunt board with on other one from an avo 40 for spare parts. Also solder many cold joints an clean the blades of the knobs.
Paint the case with Martele and put one leather slide knob that I recover from an old and broken Bakelite case
Just waiting for the red and black cap and the 3 feets.
Finally I put a Bakelite cover with stick probes
ID:	175349   Click image for larger version
ID:	175350   Click image for larger version
Old 29th Dec 2018, 8:12 pm   #20
Techman
Techman's Avatar
I just got my 'inherited' 40 MK2 out of the cupboard. It needs a good clean and the last time I used it to monitor something I seem to remember it was all over the place, so needs to be taken apart some time and looking at. I note that the end of the number on the bottom right of the scale is 961.F. which would indicate a date of September 1961. Pictures below:-
ID:	175383   Click image for larger version
ID:	175384   Click image for larger version
ID:	175385   Click image for larger version
ID:	175386   Click image for larger version
Techman is offline
