26th Mar 2018, 8:35 pm | #1 |
What's the purpose of the screening can on the VHF tuner's valve
Hello,
Sorry for a daft Q, but what's the purpose of the screening(?) can on the valve (ECC85 etc). in the VHF tuner of many 1950s radios? I have just restored some Cossors; in two of them, it was missing, and didn't seem to make the blindest bit of difference. If anything, their valves stayed cooler and there was less tuning drift. Many thanks, Nick. |
26th Mar 2018, 9:12 pm | #2 |
Re: What's the purpose of the screening can on the VHF tuner's valve
May reduce LO radiation? Not perhaps a problem with only 88-100MHz coverage (except for PMR/police etc who used the 100-108MHz band), but the LO when a set's tuned to radio 2/3/4 will be inband on sets going to 108MHz.
26th Mar 2018, 9:33 pm | #3 |
Thanks Chris [and Nick for asking] ..... I've often wondered that too ......
Red to red, black to black. Throw the switch and stand well back! |
26th Mar 2018, 9:46 pm | #4 |
Also on some sets they even screened IF stages, personally I thought this was a bit of over use of shielding, but things were made much better then.
26th Mar 2018, 9:59 pm | #5 |
I guess they act much like the conductive coating on valves from the 30's/40's.
If the can has a spring inside, would this also reduce microphony? I have an American tuner from the 1950's I'm itching to fix/write about & it's smothered in valves with screening cans! Removing them does make a difference, if you place you hand near the front-end with the cans removed, the set drifts off station ... Mark |
26th Mar 2018, 10:29 pm | #6 | |
For many years the upper part of the broadcast band was kept empty of high power broadcasts so aviation radios stood a chance. Now you've got pop music on 107.9 and an ILS localiser on 108.1. Far too close for any meaningful filtering, the receiver front ends have to work with 30mW of interferer just off channel. Receiver LO radiation can go in the channel. David
