30th Sep 2020, 1:01 am | #1 |
JVC AL-E700 BK motor does not spin
It's a linear tracker, probably 1980's. I can't locate a service manual.
Press play, the arm moves and sets down but the motor (so platter) does not spin. Removing the belt and spinning by hand, the 'no record' detect works and the arm returns. Everything else seems to work but either the motor's dead, (4 wires to it) or it's not getting power. I am reluctant to apply power to the motor to test without knowing voltage/ac/dc or which wire is which. Any clues?? Thank you |
30th Sep 2020, 10:53 am | #2 |
Re: JVC AL-E700 BK motor does not spin
Sorry I don't have the AL-E700BK manual but do have one for the AL-E500BK, which also has a 4 wire motor. The circuit shows + volts to pin 1 straight from the bridge rectifier and earth to pin 2. Speed is controlled with resistors on pins 3 and 4, which are switched between 33 and 45rpm. I could send a scan to you if that might help.
Dave |
30th Sep 2020, 8:14 pm | #3 |
Thank you a scan would be very helpful. Hopefully it shows what + volts should be..
I presume the bridge rectifier s OK as all the logic functions appear to function |
1st Oct 2020, 9:57 am | #4 |
It is the service manual for the AL-E500BK, so has the usual info in it. Will need your email to send it to you, please PM it.
Dave |
1st Oct 2020, 11:20 pm | #5 |
pm sent
4th Oct 2020, 4:28 am | #6 |
Thanks Dave for the manual.
It's given me some clues, and I suspect the motor is faulty. Its a SHP2R apparently made by Sankyo. Google does not however, give any indications as to which connections should make it spin. I tried 12V across pins 1 (yellow wire) & 2 but nothing.. Must I have voltage on one of the other 2 pins to make it go? . Pin 4 seems to be O/C |
4th Oct 2020, 7:52 pm | #7 |
There's a JVC AL-F350 at Vinyl Engine with a SHP2R13 motor where the circuit diagram shows how to connect this.
https://www.vinylengine.com/library/jvc/al-f350.shtml |
4th Oct 2020, 8:54 pm | #8 |
Thank you gents. The motor is almost certainly stuffed. Fortunately they are fairly common. I will see if I can get it apart to find out why it failed.
4th Oct 2020, 10:29 pm | #9 |
Well there is more to this motor than I thought, see attached.
There was an obvious dry joint. I need to get the brushes over the little pink 'washer' on the rotor. To do this I must first get the brass pulley off the spindle so I can pull the rotor out, but it seems firmly attached. Any ideas how to do this? |
4th Oct 2020, 10:55 pm | #10 |
Try to pull the pink washer off the armature shaft. If it will come off, position it on the end bell between the front of the brushes and the front bearing. Give the commutator a clean with a cloth and some IPA, then carefully reassemble, ensuring the brushes go over the commutator.
5th Oct 2020, 12:29 am | #11 |
Thank you. The method worked but the motor did not.
Time to find a new motor methinks.. |
5th Oct 2020, 3:42 pm | #12 |
If the motor windings all measure a sensible ohmage, it might be easier to replace the LA5531 control chip, especially as it's a through hole type, than to obtain a replacement motor. This chip is available on ebay at £4.99 each or less if you are prepared to wait and get it from China. If doing this, don't forget the capacitor, it might even be just the capacitor that has failed.
Dave |
5th Oct 2020, 8:57 pm | #13 |
I did change the capacitor and measured the voltage between the case and the two armatures, strangely 12v and 8.5v so I think the coils have had it or the brushes aren't making proper contact. It is almost impossible to line it up properly due to the way the motor was made. BER. So I will see if a donor motor comes up or will use this player for parts.
5th Oct 2020, 9:08 pm | #14 |
From the picture, this looks like a Mabuchi motor. They are in widespread use, so it shouldn't be difficult to find one that will do even if you have to use the regulator from the old one.
7th Oct 2020, 8:54 pm | #15 |
Yes the motors seem quite common as cassette recorder motors but I am concerned about the size of the brass pulley matching. With nothing to lose I'll try getting it off the spindle with heat. If that works I can obtain any motor of the SHP2R type and replace it.
12th Oct 2020, 4:48 am | #16 |
I made myself one of these
https://www.instructables.com/Cheap-...e-Gear-Puller/ which got the pulley off, then re assembled ensuring the brushes were in the right place. Now it spins. Getting the pulley on was easier. Just stick the soldering iron tip in the hole in the pulley to heat it up and drop it on the spindle. Next time I will make a mark where the pulley should fall to. The motor is slightly noisy but this was good practice if it happens again. Player now working. |
12th Oct 2020, 9:08 pm | #17 | |
Tri-ang/Hornby X04 model train motors. I am pleased that you got it working. It may have made the motor quieter if you had oiled the bearings with some sewing machine oil. You only need a tiny amount, I use the tip of a needle. It sounds like the brushes were not making contact with the commutator when you first re-assembled it, |
13th Oct 2020, 12:09 pm | #18 |
I don't know whether or not one of these motors could be made to fit if you have any further trouble: https://www.ebay.co.uk/itm/25MM-Moun....c100005.m1851
They are cheap and have a speed adjustment on them. Last edited by Fidelity Fan; 13th Oct 2020 at 12:14 pm. |
16th Oct 2020, 6:39 am | #19 |
Thanks for that. I will investigate more, Cheap enough to take a risk...
