30th Mar 2021, 10:12 pm | #21 |
Re: Problem with a SANYO TV set
TV frequencies are assigned by international agreement, so using a different channel scheme could risk interference with neighbours.
I don’t know about DTMB, but i have a DVB-T/T2 box off ebay, you can select 6/7/8 mhz for bandwidth and also output 480i or 576i ie Pal/NTSC should you so which. Of course most would use 1080P. Both Taiwan and Colombia currently use DVB-T and were ex NTSC 6Mhz countries, which presumably is the reason for flexibility... |
31st Mar 2021, 1:36 pm | #22 | |
Yesterday I resoldered the 64 pins of the TV processor. A lengthy and boring process but it worked. The TV set is already working......again.......let's see for how long. I used a fine wire tip for my soldering gun, and power it with 70 volts to reduce heat. I used rosin instead of aspirine as flux.
The "green" is still a problem when powered on. There is no green, just blue and red (and violet of course). Then after some time working the green appears and don't fail anymore. I wanted to give it another round of resoldering on weekend but my wife told me that don't touch it anymore as it is working, so....ladies command. Let's wait to see when it gives another dry joint problem. Quote:
When electrons move, things happen. There's nothing you can do that can't be done. |
31st Mar 2021, 1:52 pm | #23 |
Hi to all,
Here's what WikiPedia shows about DTMB broadcasting; Cuba is mentioned : https://en.wikipedia.org/wiki/Digita...edia_Broadcast There is often confusion with T-DMB, a digital radio format created and used by South Korea. The French nearly adopted it & finally went to DAB+ Best Regards jhalphen Paris/France |
31st Mar 2021, 3:31 pm | #24 | |
Have a look / reflow the connections on the tube base board. Probably dry joints there causing the lack of green. |
31st Mar 2021, 3:43 pm | #25 | |
In Cuba we call that PCB "chispero" (sparkler). Is any particular name for it in English?
When electrons move, things happen. There's nothing you can do that can't be done. Last edited by Miguel Lopez; 31st Mar 2021 at 3:49 pm. |
