10th Aug 2009, 1:25 pm | #1 |
Help with information on old shortwave converter
I have a 'Magnum' shortwave converter which I don't know anything about and wondered if anyone had seen one of these before and could throw some light on it. It has a single Mullard 2 volt valve - a PM1HD and the plug-in coil has 40-80 lambda marked on it. The captive power lead has a 4 pin plug on the end for HT, LT and GB so it looks like it was designed as a companion to a non shortwave broadcast receiver.
Maybe this should be with the domestic receiver threads, I'm not sure. Steve |
10th Aug 2009, 1:30 pm | #2 |
Re: Help with information on old shortwave converter
I like it. Presumably the coil has one set of windings for IF and another for the local oscillator? If you can determine the LO coverage you should be able to work out the bands covered and the IF. The IF could be variable of course with all tuning done on the main receiver.
10th Aug 2009, 2:26 pm | #3 |
A scan from a 1930-31 catalogue.
John |
10th Aug 2009, 4:02 pm | #4 |
ISTR that the Greek letter lambda was once used to signify wavelength. Hence, "40 - 80 lambda" implies 40 - 80 metres wavelength tuning range.
Al. / Skywave. |
10th Aug 2009, 4:06 pm | #5 |
Thanks John - that's great! It answers the question on how it couples to the main receiver.
Steve |
10th Aug 2009, 4:11 pm | #6 | |
Steve |
10th Aug 2009, 4:13 pm | #7 | |
Steve |
10th Aug 2009, 4:23 pm | #8 |
Hmmmm.
The circuit doesn't match the write-up in the advert, although it's logical. The interesting thing is that if it was meant to be 'plugged into the radio detector socket' as per the advert how would you elininate the L and C which were presumably already there? The existing coil might be unplugged, although the advert doesn't say so, but what about the tuning and perhaps the reaction condensor? Alan |
10th Aug 2009, 5:48 pm | #9 |
The frequency changer stage of a superhet used to be called the "First Detector", if that helps.
10th Aug 2009, 6:03 pm | #10 | |
Steve |
10th Aug 2009, 6:04 pm | #11 |
A view of the underside with the base removed
10th Aug 2009, 6:07 pm | #12 |
Wouldn't you need common, LT, HT and a connection to what was the anode so as to get the signal through to the next stage of the radio?
10th Aug 2009, 6:34 pm | #13 | |
Steve |
10th Aug 2009, 7:09 pm | #14 |
I think one has to assume that it was intended for use with a straight set not a superhet.
Battery superhets were not common in 1930 Pat G3IKR |
10th Aug 2009, 9:21 pm | #15 |
Surely this is just a complete "short wave" front end in a box which is designed to be plugged in to the detector socket of an existing receiver to provide short wave coverage. The existing receiver would then simply be used as the audio amplifier. The advert even suggests using the detector valve removed from the existing receiver in the converter, which would make the converter cheaper as it could be sold without a valve included. The advert seems to make perfect sense that way.
There's no question of it being a "converter" in the sense of the term as used now, where a mixer circuit is used to transpose a frequency band outside the coverage of a receiver into a range that is covered, either broadband (fixed local oscillator with station selection provided by the receiver tuning over the output band of the converter) eg 2m VHF ham band converter or fixed frequency output with a variable local oscillator in the converter eg Band III to band I TV converter. |
10th Aug 2009, 9:38 pm | #16 | |
Steve |
10th Aug 2009, 10:20 pm | #17 | |
HTH Al. / Skywave. |
