Old 27th Jan 2019, 1:14 pm   #1
tin0gauge
tin0gauge's Avatar
Default Which was the earliest transistor radios in UK
Hello was it the PAM 720 or the Pye P123BQ both of which I have and are similar but with different transistors ? in which order were these released ? and what came before them please ?
tin0gauge is offline
Old 27th Jan 2019, 1:32 pm   #2
Herald1360
Herald1360's Avatar
Default Re: Which was the earliest transistor radios in UK
Earliest was the PAM 710 in 1956. PAM 720 was the P123BQ lookalike, both 1957.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 27th Jan 2019, 1:58 pm   #3
snowman_al
snowman_al's Avatar
As above.
Nice Pamphonic history here: http://www.pamphonic.co.uk/index.html
snowman_al is offline
Old 27th Jan 2019, 2:16 pm   #4
tin0gauge
tin0gauge's Avatar
Thank you very useful link.
Old 27th Jan 2019, 3:14 pm   #5
Radio Wrangler
Radio Wrangler's Avatar
Wasn't the Emerson imported? An uncle had one
Radio Wrangler is offline
Old 27th Jan 2019, 6:25 pm   #6
Paul_RK
Paul_RK's Avatar
We had a thread a couple of years ago about the earliest British transistor sets,
https://www.vintage-radio.net/forum/...d.php?t=136143 ,
for which I used "Radio! Radio!" (3rd edition) to compile a timeline of those released by the end of 1957:
Mar. 1956 - Pam 710.
Jan. 1957 - Pye P123BQ
Apr. 1957 - Pam 720
May 1957 - Cossor 546
June 1957 - HMV 1410 / Marconi P60B (valve/transistor hybrids)
Perdio PR1
Aug. 1957 - GEC BC1650
Sept. 1957 - Cossor 561 (Traveller's Friend)
Nov. 1957 - KB OP21 Rhapsody
Dec. 1957 - Ace TR257 Courier
1957 unspecified - Vidor CN440 (Gem).
A few US manufacturers produced sets prior to the Pam 710. Not sure if Emerson was among them, but there were some British-built Emerson products a bit later, say around 1960.
Paul
Paul_RK is offline
Old 27th Jan 2019, 9:29 pm   #7
G6Tanuki
G6Tanuki's Avatar
From memory, some of the first Pam transistor-radios had a lower-than-usual IF [315KHz?] because Mullard/Philips - who were the people behind Pam - were having 'yield' problems with their transistors and they could not reliably produce enough transistors that would operate reliably at the more-traditional 450-470KHz IF.
[early transistor manufacture was a hit-and-miss game: you made a batch, then tested each one individually for gain, noise, frequency-response and 'type-marked' them depending on how good they were. In a batch of 100 you might get 4 or 5 that were good-enough for RF amp/frequency-changer service, another ten that had poorer HF response but would do as IF amps, another 20 that could amplify at audio, and so on. Those that didn't come up to spec were often sold to hobbyists as unbranded red/green/white-spot transistors with no guarantee of actual performance. Some manufacturers even sold off their deeply-underperforming transistors with a couple of their leads tied together for use as signal-diodes...]
G6Tanuki is offline
Old 27th Jan 2019, 9:42 pm   #8
Graham G3ZVT
Graham G3ZVT's Avatar
Paul
Indeed. I was allowed to borrow an Emerson 888 Vanguard to play with in 1961. It had a fixed 1500m LW setting. Quite a valuable item for a child's plaything.
It was the subject of my first post on this forum.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 27th Jan 2019, 9:52 pm   #9
Richard_FM
Richard_FM's Avatar
I heard Sinclair used to buy bags of reject transistors from Plessey to grade them for their kit radios.
Hello IT: Have you Tried Turning It Off & On Again?
Richard_FM is offline
Old 27th Jan 2019, 10:43 pm   #10
Paul_RK
Paul_RK's Avatar
...Some manufacturers even sold off their deeply-underperforming transistors with a couple of their leads tied together for use as signal-diodes...]
And some radio manufacturers (well, one at least...) used them as such, and included them in the transistor count to boot.
https://www.radiomuseum.org/r/fidelity_fairline.html
Paul
Paul_RK is offline
Old 27th Jan 2019, 11:31 pm   #11
russell_w_b
russell_w_b's Avatar
I have an Ultra 'Transistor Six' made in 1956. It uses Ediswan XA101 'top-hat' transistors. Still works a treat!
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
Old 28th Jan 2019, 1:10 am   #12
Paul_RK
Paul_RK's Avatar
I've one too when I find it, but I think the model dates from 1958 rather than '56 - apparently an August '58 release according to ERT.
https://www.vintage-radio.net/forum/...d.php?t=137814
Paul_RK is offline
Old 28th Jan 2019, 6:47 am   #13
Cobaltblue
Cobaltblue's Avatar
I dont think PAM were tied up with Mullard / Philip's at this time they were part of PYE and the transistors were in house Newmarket types (Also PYE)
PYE was taken over by EKCO around -1960 if memory serves and in turn by Philips in 1963 .
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 28th Jan 2019, 10:10 am   #14
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
Was it not EKCO which was taken over by PYE, not the other way round?
'LIVEWIRE?' is offline
Old 28th Jan 2019, 10:40 am   #15
russell_w_b
I've one too when I find it, but I think the model dates from 1958 rather than '56...
My mistake - my set must date from then too; just had a look in Pat Hawker's 'Radio and TV Servicing'. But the Ediswan transistors within have transistors of 1956 vintage, hence my earlier presumption about the date of the set.
Regds,
Russell W. B.
G4YLI.
Old 28th Jan 2019, 10:45 am   #16
Cobaltblue
Cobaltblue's Avatar
I think its was a merger in 1960 to form a new company British Electronic Industries but indeed by 1962 British Electronic Industries had complete control of EKCO.
Philips acquired PYE after a lengthy battle in 1967.
Lesson not to type things from memory
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 28th Jan 2019, 1:16 pm   #17
AC/HL
AC/HL's Avatar
As befitting their name, Newmarket Transistors never produced a diode. It was they who strapped transistors as diodes. Possibly rejects given the state of the art back then, but I've never seen that stated anywhere.
AC/HL is offline
Old 28th Jan 2019, 2:04 pm   #18
Edward Huggins
As early as 1956 there was no direct connection between Pye and Philips.
Pye released the version quite deliberately badged as PAM, in case their very early venture into transistors had nationwide teething problems. Old C O Stanley would not take the risk of damaging the Pye brand. When things looked more favourable by the end of 1956, the Pye version was introduced in 1957 with more developed germaniums. He was a canny old bxxxer!
Edward.
Edward Huggins is offline
