2nd Jan 2019, 3:05 pm | #1 |
Avo 7 variations
Hello, i think that it is possible to find hese Avo 7 variations.
Not sure if all exist, specially the ones with bakelite case an PF connectors from the 70´s -Avo 7 (MK1) aluminium case Metal screw and PF connectors -Avo 7 (MK1) aluminium case Metal screw without PF connectors -Avo 7 (MK1) aluminium case Bakelite screw and PF connectors -Avo 7 (MK1) aluminium case Bakelite screw without PF connectors -Avo 7 MK2 aluminium case with PF connectors -Avo 7 MK2 aluminium case without PF connectors -Avo 7 MK2 bakelite case with PF connectors -Avo 7 MK2 bakelite case without PF connectors -Avo 7X PANCLIMATIC -Avo 7 in BRAILLE -Avo 7 British army marked ZD00021 Can anyone confirm the existence of all this models and perhaps if there are more not listed. Thanks Aitor Eneko |
2nd Jan 2019, 6:18 pm | #2 |
Re: Avo 7 variations
The change in Z screw from metal to bakelite was generally around 1942, the peg on the rear of the metal screw was glass- presumably to avoid electrical continuity from the screwdriver to the movement. These screws were interchangeable so it is not possible to know whether an early meter started out with the Z screw that it now has.
From what i have seen some early Model 7's were made in a shadow factory, and the parts availability at that site may have changed from month to month. Dave |
2nd Jan 2019, 7:10 pm | #3 |
Thanks, and what about the model of the 70’s? Does exist Avo 7mk2 with bakelite case and with or without Pf conectors in that era?
