1st Jul 2008, 7:52 am | #1 |
Garrard 2025TC
I have a Garrard 2025TC record deck and the pick up weight seems rather heavy. I have noticed a greying effect on my records after playing them on this deck (but it doesn't seem to have damaged the record). i was wondering if this is caused by the pick up being to heavy. I cannot see how the weight can be adjusted on the arm though.
1st Jul 2008, 11:07 am | #2 |
Re: Garrard 2025TC
there is a spring under the arm ISTR possibly with a screw accessible from above. sure someone else on here who has one to hand will advise.
1st Jul 2008, 3:08 pm | #3 |
Re: Garrard 2025TC
Yes there is the adjusment screw on top at the front of the pivot, does it look as if someone has already been having ago at it? If you have a stylus protector put this over the stylus and then without forcing it, lift the arm up, it goes no more than about thirty degrees. With a torch handy, look along the length of the pick-up arm amd right underneath the black plastic there is a spring going from front to back, make sure this is still attached (and still present!) though it is well hidden.
The heavy tracking might be related to your other fault, it is the same thing we are talking about? If the stylus has become dislodged from the V it sits in or is tracking too heavy it could give the symtoms you describe. Geof |
1st Jul 2008, 4:47 pm | #4 |
Re: Garrard 2025TC
IGNORE the above, I made a slight error The adjuster on the top is for the side pick-up cueing device lever. This also sets the height of the pick-up to lift off the stand, and should give at least two millimetres of clearance.
The tracking force appears to be fixed by the front to back (under the pivot plastic cap) spring and with a Sonotone 9TAHC is set at just under three grams. But it did give an excuse to drag out my Bush SRP51 (with my improved regulated power supply) to give it an airing. And isn’t it more satisfying to put on a record than choose from an MP3 menu! Geof |
1st Jul 2008, 6:07 pm | #5 |
Re: Garrard 2025TC
Don't forget that the 2025 has a release lever at the rear..push this to the side and you can then raise the arm right up ..that should help you locate the spring and adjustment better.
1st Jul 2008, 7:41 pm | #6 |
Re: Garrard 2025TC
3rd Jul 2008, 9:03 am | #7 |
Re: Garrard 2025TC
I have looked under the arm and i can see a spring attached by a loop at the back and the other end is attached to a plate on the arm with holes punched into it. However there is no tension in the spring at all. The spring looks in good condition but should there be some tension there?
3rd Jul 2008, 9:52 am | #8 | |
Re: Garrard 2025TC
Try moving the end of the spring to a hole a bit nearer the cartridge, and see what happens. Nick. |
3rd Jul 2008, 9:54 am | #9 | |
Re: Garrard 2025TC
Geof |
12th Jul 2008, 9:42 am | #10 |
Re: Garrard 2025TC
I have checked that the stylus is correctly seated in the cartridge and that seems ok. I am sure that the weight is more than 3 grams as it feels quite heavy. i have looked underneath the arm and i cannot move the spring as i cannot release it from the plate. ( i am worried that i will damage it) So i have stuck a lump of blu-tac to the rear of the tone arm in an effort to counterbalance it and have noticed a reduction in the "greying effect" on the records, so i am on the right track.
