6th Mar 2011, 7:16 pm | #1 |
Marconi 911
Hi
Can anyone help with some advice. Just bought myself a Marconi 911 and seems to be missing a knob or something on the side as I have the holes but it’s also not connected to anything inside? (see pictures) Knob or vandalism? Paul |
6th Mar 2011, 7:26 pm | #2 |
Re: Marconi 911, need some advice
I don't know if this will help give you a clue Paul. It is from the BVWS CD and states that the set should have three knobs.
6th Mar 2011, 7:28 pm | #3 |
Sadly the latter - I have one of these delightful sets and there isn't meant to be a hole there !
Probably the usual makeshift on off switch to circumvent a failed volume control, or perhaps a speaker switch ? The knob above it is also incorrect Andy |
6th Mar 2011, 7:30 pm | #4 |
It looks like vandalism. Check out the following link. http://www.radiomuseum.org/r/marconi...phone_911.html Regards Andy |
6th Mar 2011, 7:37 pm | #5 |
Thanks all for the information.
Andy, would you be able to take a photo of your knob, would like to compare with the one I have attached. Paul |
6th Mar 2011, 7:39 pm | #6 |
Sorry Andy, just realised that sounded a bit strange.
Could you take a photo of the knobs on your radio so I can compare with the one’s I have on my radio. That’s better. Thanks |
6th Mar 2011, 7:57 pm | #7 |
Chortle ! Straight out of a Carry On movie - Ooh Matron
Anyway, pics as requested, in haste. Gives you the general idea. The 'volume knob' ( LHS ) has the word engraved into the face. hope this helps My set has had remedial work done I would guess in the 60s to get around an open field coil in the speaker. It also had an open circuit MW coil and a duff IFT. Not a great performer. The speaker is way too small for the cabinet. Andy PS Can you tell me the serial # of yours ? A/4 1xxxxx at a guess |
6th Mar 2011, 8:09 pm | #8 |
Thanks for the info and pics Andy, very helpful. Looks like 2 of the tree knobs I have are wrong, ******.
Suppose you don’t know a good place to look for the correct one’s? Please find a pic of the serial. Paul |
6th Mar 2011, 11:12 pm | #9 |
Excellent, thanks
9 of these now known to exist. Hope to find some more ! Andy |
6th Mar 2014, 8:21 pm | #10 |
Make that 10. I've just found one in a bit of a sorry state in a bin in Bermondsey.
Case is smashed in half but the chassis looks intact, all valves present. Speaker ok too at first glance. The chassis, valves and case had half-damp blue paint on them, cleaned most of it off and will start checking out the circuitry soon. |
6th Mar 2014, 9:15 pm | #11 |
11 but mine doesn't have it's back.
It appealed to me because the Chassis is upside down. I bought it in a mixed lot of sets around 1990. I have seen 3 or 4 for sale on Ebay though over the last couple of years. Cheers Mike T
7th Mar 2014, 1:32 pm | #12 |
Thanks for the update chaps - I had 13 on file
7262 9057 9451 100946 103154 103676 104300 104350 106762 109021 111677 116702 117664 Any chance of your serial numbers please Survival rate for these is still quite low ! Andy |
7th Mar 2014, 5:44 pm | #13 |
Hi Andy
A picture tells a thousand words they say Cheers Mike T
7th Mar 2014, 8:01 pm | #14 |
Re: Marconi 911
Or about 13 unless you add a very detailed description of the label itself and its precise discolourations etc
7th Mar 2014, 8:22 pm | #15 |
Re: Marconi 911
I reckon there's at least a half dozen words about the mark on the rivet
Cheers Mike T
7th Mar 2014, 8:27 pm | #16 |
Re: Marconi 911
Sadly my unit doesn't appear to have a serial number tag, otherwise I would gladly submit it.
The case (well, one half of it anyway) still has the label with the different valve positions etc. It looks like the unit was switched on when it shouldn't have been as there are a few burnt looking wires and lots of insulation falling off. I spent a fair part of last night trying to sort out the mains transformer. The insulation on the fly wires had gone on every single one, so I cut the wires close to the transformer and soldered on new leads. It is by no means a work of art but I checked all the primary & secondary connections and they all seem ok! (The 'trader' sheet for this model is very helpful, it lists all the d.c. resistances for the taps.) Next up I'm going to try reforming the can electrolytic and replacing all the other iffy wiring. Following that, I'll replace all the coupling caps and just try to get the amp bit working. It is never going to be beautiful again (unless I can find a new case) but it might just sing. |
7th Mar 2014, 8:29 pm | #17 |
Re: Marconi 911
The one on the right that looks like a with a red nose?
7th Mar 2014, 11:02 pm | #18 |
Re: Marconi 911
The chassis has 18855 stamped on it, not sure if that is actually the serial number though.
7th Mar 2014, 11:11 pm | #19 |
Re: Marconi 911
Andy,i also so have a 911,not sure yet of serial number though.
