Where To Get Sets and Parts For discussions about swapmeets, rallies, NVCF and BVWS, car boot sales, antique and charity shops, dealers, newspaper adverts, the local tip and just about any other source of equipment (other than eBay). |
5th Mar 2022, 4:45 pm | #1 |
Digital Audio Interface Receiver - CS8412-CS
I'm looking to source a replacement CS8412-CS as the existing one has lost a leg with no copper remaining on the body to reconnect!
I am, however, confused by the markings on this? What does GYATKG9606 mean and do I need an exact match for a replacement? I've seen others for sale but with different letter and number combinations? And where would be a reliable source to purchase from?
BVWS Member |
5th Mar 2022, 5:14 pm | #2 |
Re: Digital Audio Interface Receiver - CS8412-CS
Datecode? Week 6 of 1996 perhaps? The rest might be plant, revision, and mask serials.
5th Mar 2022, 5:43 pm | #3 |
One has to ask how it lost that leg? If there is but the weeniest bit of some conductor left in the hole a bit of conductive paint like used for heated windscreens may connect enough to make it work. Drop a bit in the hole and poke a wire in sort of thing.
5th Mar 2022, 6:43 pm | #4 |
Hi little diode have them at £25.00 or china for £4.00 on ebay but maybe not genuine ? but not everything from china is fake
mick If you are careful it maybe poss to solder a THIN wire to the stump of the leg i have done this in the passed with good outcome. |
5th Mar 2022, 9:08 pm | #5 |
I believe the CS8412-CS pin compatible replacement/upgrade was CS8414-CS and these may be more readily available
5th Mar 2022, 9:40 pm | #6 |
There just the faintest hint of some remaining metal on the body of this component:-
What do people think - repairable or just replace?
BVWS Member |
6th Mar 2022, 1:26 am | #7 |
Reparable Thin thin wire steady hand small tip on iron Mick
