Old 12th Jun 2008, 7:03 pm   #1
HMV 1120
HMV 1120's Avatar
Default R.107 tuning drive
It hates me. And what is even more infuriating is that it was working perfectly when I received the set. The small (fine) tuning control is essential to the operation of this set, yet it has ceased to operate. Turning the small knob does absolutely nothing unless it is forcefully pushed in and rotated slowly until it 'catches', and then only at certain positions on the dial. And then it will sometimes only work in one direction.
Any pointers? I've had a look in the set but nothing has caught my eye. The tuning drive seems untouched. Are there any components that might wear out? I am wondering if the spring assembly needs replacement - although any repair would involve invasive surgery.
Yours exasperatedly, Robs.
Real radios glow in the dark
M6GLD
HMV 1120 is offline
Old 12th Jun 2008, 7:42 pm   #2
Sean Williams
Sean Williams's Avatar
Default Re: R.107 tuning drive
Rob,
It needs stripping and cleaning!
From memory it is an epicyclic drive - a small shaft, that drives three concentric ball bearings via friction, this in turn drives an outer collar, which is coupled to the tuning capacitor.....
Pull it to bits, and have a go!
Pity you arent closer, or I would have looked at it with you
Sean
Sean Williams is offline
Old 13th Jun 2008, 8:41 am   #3
HMV 1120
HMV 1120's Avatar
'It needs stripping and cleaning'
I can see it now... it'll all go 'PING!'
Well, if thats what it needs... would it benefit from a very light oil? The stuff I have for a clock movement?
I'll move it to Cambridge tomorrow, then start the fun.
Regards, Robs.
M6GLD
HMV 1120 is offline
Old 13th Jun 2008, 10:36 am   #4
RobinBirch
RobinBirch's Avatar
Be careful if you lubricate this. It may need greasing with a thixotropic grease such as hylomar which will give you a stiff drive when slowly rotating.
Robin
RobinBirch is offline
Old 13th Jun 2008, 1:21 pm   #5
Sean Williams
Rob, Cambridge is a bit closer to me.....
Sean
Old 16th Jun 2008, 11:22 am   #6
RobinBirch
RobinBirch's Avatar
Whoops, wrong gloop. The grease type is kilopoise, hylomar sticks cylinder heads on
Robin
Robin
Old 16th Jun 2008, 8:30 pm   #7
HMV 1120
HMV 1120's Avatar
Glad to hear it Sean. So I won't be the only nutter round here then...?
The set is currently banished to the shed until I get some Emery cloth and Hammerite. According to mum I live in a bedroom and not a scrap heap. Hmm... One mans rubbish is another mans treasure...
Luckily the Radar set is quite tidy. I'll be sneaking it past customs in a few weeks ( Currently it's in devon), so I have plenty of time to get this one up to scratch.
thanks all and kind regards, Robs.
M6GLD
HMV 1120 is offline
Old 16th Jun 2008, 10:37 pm   #8
Sean Williams
Please, no hammerite! - it looks flipping awful!
Nice drop of olive green cellulose!
Sean
Old 18th Jun 2008, 5:40 pm   #9
HMV 1120
HMV 1120's Avatar
But hammerite is cheaper!! and it's in the garage. How about a satin coat afterwards?
M6GLD
HMV 1120 is offline
Old 18th Jun 2008, 7:26 pm   #10
Sean Williams
Its 'orrible - what a mean thing to do to a wonderful radio!
Seriously, if you must repaint it then do try something that looks right.
Although not rare, they arent as common as they used to be!
Old 19th Jun 2008, 4:41 pm   #11
HMV 1120
HMV 1120's Avatar
Fair enough. I'll add to my list of things to buy, Money permitting. Funny thing, that list. It never seems to get shorter.
So, Cellulose paint in bright pink then?
M6GLD
HMV 1120 is offline
Old 19th Jun 2008, 11:17 pm   #12
Skywave
Talking Re: R.107 tuning drive
Sean
All a question of personal taste, Sean.
Personally, I think drab olive green looks awful & would go for grey or silver Hammerite every time. After all, grey Hammerite - or something very much like it - was good enough for Eddystone (thinks of his S888A receiver).
Al.
Skywave is offline
Old 20th Jun 2008, 12:34 pm   #13
Herald1360
Herald1360's Avatar
Only if it's luminous- it has to glow in the dark, remember?
Herald1360 is offline
