Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets and Parts Wanted (private buyers only, no swaps)
Sets and Parts Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Old 2nd Jul 2023, 8:21 pm   #1
yampy187
yampy187's Avatar
Default BRC 3500 Convergence panel wanted
Looking for a complete BRC 3500 convergence panel for my HMV Colourmaster 2715.
The one in the set has many toasted crumbling pots and a melted transductor. Making it impossible to set the convergence/pincushion correctly.
If anyone has one available please let me know. Costs covered of course.
Cheers.
Jan
yampy187 is offline
Old 2nd Jul 2023, 8:52 pm   #2
neil29
neil29's Avatar
Default Re: BRC 3500 Convergence panel wanted
Hi Jan, Are the transductors anything like the ones used in the Decca bradford, bush A823, Philips G8 etc. if so i might be able to help.
Neil.
neil29 is offline
Old 2nd Jul 2023, 9:39 pm   #3
yampy187
yampy187's Avatar
Hi Neil.
Yes, it does look the same as the one used in a Bradford. Do you know if they the same impedance/inductance?
If they are, I have a Bradford 30 in the loft, With a duff lopt I can pinch one from!
Cheers. Jan
yampy187 is offline
Old 2nd Jul 2023, 9:53 pm   #4
Chris55000
All of the early 1970s delta–gun CTVs used the same pincushion–correction transductor, Mullard AT4041/07, with the two field–scan section windings connected in series or parallel and then in series with the field–deflection circuit, whilst the line scan windings are connected across the line deflection–coil circuit with a limiting resistor of between 120 Ω and 470 Ω.
The N/S phase correction inductor, where used, is usually connected across the field–scan section windings of the transductor with a tuning/shaping capacitor in series with one side of it!
The exact circuit details vary slightly from design to design, and also between valved and transistorised frame/line timebases, but they're all interchangeable!
Chris Williams
Chris55000 is offline
Old 2nd Jul 2023, 10:31 pm   #5
yampy187
yampy187's Avatar
Hi Chris. Thanks for that useful info! I did not know that they were all interchangeable!
I’ll create a thread in the television section when I get started on it.
Still looking for a convergence panel to scavenge some pots from
Cheers.
Jan
yampy187 is offline
Old 4th Jul 2023, 4:13 pm   #6
pastyboy
pastyboy's Avatar
Mark Clinton may be able to help with a panel he had a set off me that could be a breaker. You might have to get him on the facebook group.
I'm a callins, get me outta here ! (I am also an erie but it's my day off)
pastyboy is offline
Old 5th Jul 2023, 12:44 pm   #7
G6ONEDave
G6ONEDave's Avatar
If you can't get a complete panel, post a pic of the actual parts you need and their values. I can then have a look through my drawer of convergence parts.
Dave
Quote "All is hyperthetical, until it isn't!" (President Laura Roslin, Battlestar Galactica)
G6ONEDave is offline
Old 5th Jul 2023, 12:50 pm   #8
dazzlevision
You have a PM.
dazzlevision is offline
Old 6th Jul 2023, 4:21 pm   #9
yampy187
yampy187's Avatar
Thank you all for the replies.
Dazzlevision is kindly going to sort me out a complete board.
Mods, This thread can now be closed
Cheers. Jan
yampy187 is offline
