Old 7th Oct 2021, 8:08 pm   #1
Edward Huggins
Default Tape head demagnetisation
I have been using R2R and cassette units for over 60 years now. In that time I've always cleaned heads with IPA and the well-regarded ALLSOP cased cleaner for cassettes. But I've never attempted to demagnetise a head on any unit. I have been nervous about using a Wand type or a Cassette cased type for fear of accidentally inducing stray magnetism by misuse. What should I look out for in using a Wand type system, especiaily the rate of withdrawal away from the heads? I've noticed that some cassette cased types use a crude rotating magnet and others have quite dense PCB based circuity. Indeed, can demagnetisers actually make things worse? Please help this Old Codger out with an Idiot's Guide!
Edward.
Edward Huggins is offline
Old 7th Oct 2021, 10:30 pm   #2
Ted Kendall
Default Re: Tape head demagnetisation
The aim is a gradual increase in flux to saturate the head, guide or shaft, followed by a gradual decrease to virtually nothing, leaving the target in a degaussed state. Compared to the 50 Hz field rate, any comfortable speed of approach or withdrawal is gradual. The major hazard is the risk of scratching the head - actual contact is not necessary, and it is advisable to put a sleeve over the bare metal shaft of such as the early Ferrograph defluxer.
So, taking care to clear the immediate area of recorded tapes, switch the defluxer on at arm's length from the machine. Bring smoothly up to the head, pause a beat and then withdraw to arm's length and switch off. You may want to treat each head, shaft and lifter separately. Also, it is polite to ears, amplifiers and meters alike to do this with the equipment switched off
Ted Kendall is online now
Old 8th Oct 2021, 5:38 am   #3
Radio Wrangler
Radio Wrangler's Avatar
The bit about driving to saturation is very important.
Ferromagnetic materials have a well-known B-H curve, going into saturation at the ends and having hysteresis between the upwards and downwards directions of change.
The demagnetiser has to be strong enough to drive the target item round its hysteresis loop. The non-linear saturation effect centres-up the magnetisation. As you slowly move the demagnetiser away, the hysteresis loop being circumnavigated at 50Hz gets smaller and smaller until you're left with a part without remaining permanent magnetisation.
So the magnetic 'overdrive' does the demagnetisation. And the gentle withdrawal is how you get out of overdrive without leaving some magnetisation from abruptly stopping the demagnetiser. Get the demagnetiser well away from all important things before turning it off.
A bit of tape or sleeving over a bare metal pole piece of a demagnetiser allows you to touch your heads and tape guides, capstan etc without scratching. This allows you to know that you got close, to a defined distance. Just waving it about nearby is a bit uncertain.
Radio Wrangler is online now
Old 8th Oct 2021, 5:28 pm   #4
MeerKat
MeerKat's Avatar
I have taken the rough edges off mine with emery cloth and use a bit of heatshrink when doing the head faces.
Andrew
Illegitimi non carborundum
MeerKat is online now
Old 8th Oct 2021, 6:13 pm   #5
Ted Kendall
Incidentally, it is as well to note that Revox specifically advise against using a deguasser on their cassette machines as it can cause premature demagnetisation of the capstan motor rotors. To be fair, I have never had magging-up trouble with these transports.
Old 9th Oct 2021, 10:25 am   #6
Edward Huggins
Thank you all for the detailed replies received so far. I will approach the use of a Wand with due caution. Can anyone offer any more of the issues (if any) in using a cassette cased degauser? Obviously my Nak 2 is getting on now, and my Philips Black Tulip even more so, but don't want to risk anything.
Edward.
Old 9th Oct 2021, 2:06 pm   #7
TIMTAPE
Classic Naks have lovely precise head adjustments but the mounting has some fragile plastic parts. Be careful not to accidentally knock the head as you bring the demagnetiser tip onto the head face.
TIMTAPE is offline
Old 10th Oct 2021, 4:12 pm   #8
AndiiT
AndiiT's Avatar
Hi, there's a train of thought that says head demagnetising is only necessary on three head machines, as with a two - head machine the record/play head is often (though not always) connected in opposing phase during record and playback modes, so is subject to a "self demagnetising" effect. Opinions on this do differ, however.
The advice about gradually decreasing the magnetic field during the process of demagnetising is important, otherwise you just end up with a head that is more magnetised than when you began
Regards
Andrew
AndiiT is offline
Old 10th Oct 2021, 4:50 pm   #9
Radio Wrangler
The bias field at a record or record/replay head doesn't drive things into saturation (for obvious reasons) it just goes a little less than half-way in order to gloss over the central kink. So it isn't an effective degausser.
The erase head does get clobbered.
Erase oscillators in tape machines need to be designed to diminish steadily in amplitude and not stop abruptly. On some good machines you'll find a small reservoir, but the oscillator also needs to work down to low levels before oscillation stops. This isn't obvious, nor does it get mentioned in most texts on tape recorders.
Old 10th Oct 2021, 5:23 pm   #10
Boulevardier
Very interesting point - obvious now you point it out, but it hadn't occurred to me before!
Mike
Boulevardier is online now
Old 10th Oct 2021, 5:37 pm   #11
ms660
ms660's Avatar
Percy gives it a mention in his book.
Lawrence.
ms660 is offline
Old 10th Oct 2021, 5:57 pm   #12
Radio Wrangler
A reason not to muck around with track selection switches while recording. Can leave an erase head magnetised.
Old 10th Oct 2021, 7:46 pm   #13
barrymagrec
Definitely - Twin Track Leevers Rich machines supplied to the BBC had a big red label to this effect by the track selection switch.
barrymagrec is offline
Old 11th Oct 2021, 1:43 pm   #14
ricard
ricard's Avatar
Mightn't a cap across the erase head winding forming a damped resonant circuit be enough to cause erase signal to drop off gradually enough?
ricard is offline
Old 11th Oct 2021, 2:00 pm   #15
ms660
ms660's Avatar
Often there's a capacitor across the oscillators HT that remains in circuit to provide the oscillator run down when it's HT feed is disconnected, Ferrograph for instance, 16uF in the Series 2, 8uF in the Series 5.
Lawrence.
ms660 is offline
Old 11th Oct 2021, 2:46 pm   #16
Radio Wrangler
It's difficult to get oscillators to run down to very low levels, so a two-pronged attack is used.
A capacitor holds the power supply up and stops things falling too quickly, and an LC oscillator running quite high Q is used to store AC energy and slow the decay once the active devices in the oscillator drop out. Good erase oscillators use something like a pot core or IFT and couple the erase head windings to it. If one channel isn't in use, there is a dummy head circuit for keeping operation normal. bias is done with high voltage into high value resistors to approximate a current source. Moderate erase oscillators use the erase head, but keeping DC out isn't always good.
Some people tried R-C multivibrators.... no stored AC energy, no high voltages. Problems!
Old 11th Oct 2021, 4:10 pm   #17
barrymagrec
Pretty much how Leevers did it. Pair of ECC82s in parallel as a push pull oscillator using a Mullard pot core as a tuned O/P transformer. 8uf cap on the HT to give a controlled decay. The erase head was coupled as a series tuned circuit for maximum erase current. Running at 95kHz with a double gapped Ferrite erase head it would erase a peak level tone into the noise (better than -80dB)
