3rd Mar 2012, 4:33 am | #1 |
Akai M-10
Trying to track down a fault with an Akai M-10 reel to reel tape deck.
Seems both preamps aren't working. No needle deflection on playing a recorded tape, or trying to record a tape. Some hiss from speakers when volume turned to full. Service manual suggests checking B+ voltage, but the schematic is very light on with voltage details out of the power supply, so am a little stumped. Any help greatly appreciated. I am assuming it's a power supply issue, as guess it's unlikely that both channels would have died (although not impossible). Thanks, John |
3rd Mar 2012, 5:27 am | #2 |
Re: Akai M-10
B+ voltage, its solid state, are you talking the transistor voltage?
-Chris |
3rd Mar 2012, 9:47 am | #3 |
Re: Akai M-10
John, Can you post the schematic on here, I would think +B would be around 20V - 30V.
3rd Mar 2012, 9:55 pm | #4 |
Re: Akai M-10
I have a printed copy, but also available online here:
http://www.obsoletemedia.com/tapedec...l/schem2-1.htm http://www.obsoletemedia.com/tapedec...l/schem2-2.htm |
3rd Mar 2012, 10:18 pm | #5 |
Re: Akai M-10
Yes the machine is solid state, B+, you mean transistor voltage.
You need to check the power supply unit and make sure that its outputting voltage. Look at the capacitors and make sure one hasnt gone leaky. -Chris |
