Old 27th Sep 2022, 11:21 pm   #1
JohnG6DFH
Default Trio 9R59DS
Hi I just purchased a Trio 9r59ds and want to connect a digital frequency display,only I haven't got a clue where on the receiver to connect it to,I got the circuit diagram if someone could show me where and how to connect it thank you.
JohnG6DFH is offline
Old 28th Sep 2022, 9:15 am   #2
roadster541
Default Re: Trio 9R59DS
I hope that you have a frequency meter with a fast refresh rate, to keep up with the drift!
More seriously, check to see if the OA2 regulator has been fitted; this does improve stability. I do like my 9R-59DS and must get its matching TX88D up and running.
I haven't fitted a crystal calibrator to the 9R59-DS, if I need to calibrate it, I use the transmitter on "net", with a digital frequency meter using a telescopic aerial.
73
Rod
M0LXY
roadster541 is offline
