6th Mar 2019, 3:56 pm | #21 | |
Re: paper in oil capacitors
However since one capacitor is being charged on the positive half cycle and the other on the negative half there is current flowing in the transformer during the entire mains cycle exactly as it would in full wave rectification so there is no extra strain on the transformer or derating required, normal VA calculations apply. Peter |
6th Mar 2019, 4:03 pm | #22 | |
I was then able to overwind with sufficient turns for the heater secondaries. I wound two secondaries simultaneously (Bi-filar) to give 2 X 3.15V which I then connected in series with the centre tap connected to ground. Obviously I chose a torroid with sufficient VA for both HT and Heaters. Peter |
6th Mar 2019, 4:16 pm | #23 |
Re: Paper in oil capacitors.
Some Schades curves for half wave, full wave and voltage doubler, as good as flat for most apps once critical C (reservoir) is used.
Lawrence. |
6th Mar 2019, 4:37 pm | #24 |
If you don't want to use electrolytics, it could be worth you looking at 'motor capacitors' which are available remarkably cheaply and in high-voltage ratings. The Italian Ducati company offer a range, some of which are specced for use in 3-phase 440VAC applications.
Example: https://uk.rs-online.com/web/p/polyp...itors/3888061/ |
6th Mar 2019, 6:58 pm | #25 |
Compton's first series of post-war electronic organs used exclusively PIO capacitors for reservoir and all smoothers of the 15+15W amplifier based on popular octal beam tetrodes, supplied via two popular octal directly-heated rectifiers in parallel. CLC for the main HT - typically 10H @400mA tuned by 0.25μF - followed by RCRC for the preamp, all C's 8μF. The PSU chassis was slightly smaller than the PA but much heavier. Early versions with triode-connected output stages used no electrolytics in the circuit at all. The tetrode and ultra-linear versions that followed had cathode bypass electrolytics, but the PSUs retained PIO parts until they switched to solid-state amplification in the 1960s.
However, in the early 60s they introduced some smaller models with physically more compact single-channel 20W amplifiers all on one chassis. These still had CLC smoothing but with a much smaller choke and 32+32μF electrolytic reservoir and smoother, served by an indirectly-heated rec. The hum in both cases is admirably low, but the toe-injury potential of the models with the big choke and 8μF caps is very high indeed. The inertia in changing these to use electrolytics may have been influenced by the expectations of longevity. Subject to service contract, they were guaranteed for 21 years! Last edited by Lucien Nunes; 6th Mar 2019 at 7:10 pm. |
