Old 28th Jun 2016, 9:30 pm   #1
rockinmark
Default Reel tape retainers
Hi does anybody know where you can get the reel 2 reel tape spool rubber retainers
Mark
rockinmark is offline
Old 28th Jun 2016, 10:12 pm   #2
Reelman
Reelman's Avatar
Default Re: Reel tape retainers
Well, if you have a time machine Tandy used to sell them.... But seriously I have heard suggested using the rubber "corks" used for wine making. It is possible to get them with one hole already drilled.
The original reel retainers are all pretty old now and if anything like mine are going hard and so not so effective.
Peter.
Last edited by Reelman; 28th Jun 2016 at 10:13 pm. Reason: More appropriate word used
Reelman is offline
Old 29th Jun 2016, 2:38 am   #3
TIMTAPE
A rubber doorstop can work.
TIMTAPE is online now
Old 29th Jun 2016, 11:09 am   #4
P.Pilcher
The suggestion of a rubber bung for winemaking suggests that a bored rubber bung of an appropriate size may work. A large selection of such bungs are available from Amazon.
P.P.
"Ohm's law rules here" - Oxygen free speaker cable not required! (Quote: Quad Service lab)
P.Pilcher is offline
Old 1st Jul 2016, 1:52 pm   #5
JohnBHanson
I have used grommets that are used for taking electrical wires through cases. Works wonderfully.
JohnBHanson is offline
Old 2nd Jul 2016, 9:52 am   #6
rockinmark
Thanks I didn't think of other things to use all sound good ideas
Old 16th Jul 2016, 12:31 pm   #7
AkaiRick
Wink Re: Reel tape retainers
I have used "SUGRU", a new rubber type adhesive that I found on Ebay.
1. Roll a lump of SUGRU into a ball approximately 5mm dia.
2. Squash the ball to the size of a 10p piece.
3. Place it centrally across the hole in the retainer.
4. Knead the Sugru into the surface of the retainer around the hole.
5. With the point of a pencil, create a hole in the Sugru slightly smaller than the original retainer hole - knead the excess Sugru (that forming the hole has created) into the retainer to leave a contour similar to the original underside of the retainer.
6. Leave for 24 hours.
Voila!
AkaiRick is offline
