Old 9th Sep 2007, 4:51 pm   #1
cor hummel
Default Help with the Heathkit DX20 CW Rig
i have some problems with the rig dx 20 power getting down and down.
i have during transmitting a short noise patch and power in watt meter getting down the occ most go tunr to 90 procent de copler to 50 procent the end tube til 10 procent a getting not more at 10 watt .
witch amateur kan help me or have link fot info to repair this prioblem .
i have inspectit several times can found anny ting .
greetting from cor
holland
cor hummel is offline
Old 9th Sep 2007, 5:23 pm   #2
Station X
Station X's Avatar
Default Re: Help with the Heathkit DX20 CW Rig
If you don't have it you can download the circuit here:-
http://www.vintage-radio.info/heathkit/index.htm
Your post is a bit difficult to understand. Have you tried operating the rig into a dummy load? What happens to the grid and anode currents when the fault is present?
Graham. Forum Moderator
Station X is offline
Old 9th Sep 2007, 7:03 pm   #3
cor hummel
its given 5 watts .
a short time ago its haveb an noise pets i can find the problem .
are there schematics from repair men to look at wots the problem coutn be .
greettting cor
Old 9th Sep 2007, 7:05 pm   #4
cor hummel
i have de sheets but i can not see fisuely wats rong on the rig
Old 9th Sep 2007, 8:17 pm   #5
Station X
Station X's Avatar
As I said in post two operate the rig into a dummy load. If you haven't got one use a mains light bulb.
When the fault is present check whether the grid and or anode currents have changed. If the grid current drops the problem is in the oscillator/driver stage. If the anode current changes you have a fault in the PA stage.
Tell us what you find.
Old 10th Sep 2007, 11:20 am   #6
cor hummel
hai i wil do so you told me .
perhaps is it the pa stage but i have not tested yet.
i think to night .
sorry for my inglisch
greetttings cor from holland/utrecht
Old 12th Sep 2007, 1:02 pm   #7
cor hummel
i have do the test the diver seems to give output enouf de end tube olso .
but wen a move de chassis vrom the end tube wiggeling de power get some higher en lower out put.
i will test now nieuw elco,s en then i look agan its seems to bee bee de elco i thing the voltage is no 600 volt that is in the manual at the anode en de voltage at the driver is about 250 volt .
de tube vor making to make ormal voltage is making some tinkeling noise later wens its warm enouf its the tinkeling noise stops ..
greettting cor
Old 13th Sep 2007, 12:59 pm   #8
cor hummel
I heve found the problem.
i have made probe for HF some c and diodes its works great find the problem with the end tube anode voltage war low at the 2.5 henri i fikst the henri lose contact its works great again i have started at 10 watt to heat some up than i have reac about 2 ours den at turn the rig to about 40 watt its works great a chort time at 50 watt.
thanks now i kan make music again.
at 48 mtr and 79 .
greetttings cor
