Television Standards Converters, Modulators etc Standards converters, modulators anything else for providing signals to vintage televisions. |
31st Dec 2013, 1:29 am | #1 |
My First 405 output using PC
Hello,
This is my first post to this most interesting of sites. Recently visiting Ally Pally has rekindled my interest in 405 TV. I recently acquired a Sony 9-90UB which is working fine ( and also a Sony 9-306UB which is showing two images one above the other ? ) I still have my parent's Baird M708 Dual standard colour TV that they bought at Harrods in 1967. Any way following Kat Manton's ideas I have successfully to-day got a 405 line picture out of my 9-90UB. I'm using a different mode line of 704x384 @ 8M424 as I don't want to re-sample the horizontal and 384 vertical only needs two coefficients in my software interpolator . The original 405 spec seemed to have 385 active lines. I did build a 525-625 field store/converter in the mid 1980's and a CCD 625/405 converter in the late 80's both of which are somewhere in my loft. Now to improve it... |
31st Dec 2013, 1:53 am | #2 |
Re: My First 405 output using PC
Interesting! Can you please post the important bits out of your xorg.conf file? I'd like to have a go at 405-line TV .....
31st Dec 2013, 10:04 am | #3 |
Welcome to the forum!
Yes indeed that is great. As the owner of lots of old PCs (& some 405 line TVs) I'm tempted to have a go too. It would be great to have a click-by-click account of what to do. From some of your "key-words" I presume you are using Linux. Starting from a hardware spec, up through installing an appropriate version of Linux and then the config and software would be fantastic. It would also help some of us understand each step. Graham
Half my stuff is junk - trouble is, I don't know which half! |
31st Dec 2013, 3:07 pm | #4 |
Welcome from me too! Love the VT-33E(?) as well.
N. |
1st Jan 2014, 1:33 pm | #5 | |
Thanks for the welcome guys.
Its actually an Hitachi VT-39EM Multi System PAL NTSC 3.58/4.43 Secam and MESecam I'll try and post more details when I get a chance. |
2nd Jan 2014, 4:30 am | #6 |
I will keep an eye on this one for sure.
Where are you getting your base band video from on the computer? |
2nd Jan 2014, 10:46 pm | #7 | |
software 625(576) -> 405(384) interpolated images. |
3rd Jan 2014, 9:00 am | #8 |
Looks impressive!
Jac |
4th Jan 2014, 2:50 am | #9 |
I was thinking of how you get the driver to work with a TV out card.
4th Jan 2014, 11:47 am | #10 |
Not quite sure if you mean hardware or software driver.
I used Kat Manton's sync combiner: see forum page "FothTV (405-line from a PC) - KISS Circuit" and attached photo. This is then feed into a VHS video input that then uses the VCR's UHF and 6MHz sound. The Sony 9-90UB will show 405 TV on UHF if both 405 & 625 buttons are pressed in together. Combines Green, H & V. Driver is standard Nvidia uses VGA connector and also use s-video into conventional 625 TV. |
4th Jan 2014, 2:45 pm | #11 |
Crocodile clips and component leads poked into the DIN socket!
That's the way to do electronics
5th Jan 2014, 7:35 pm | #12 |
When I used to repair VGA screens. we used to get jobs in that were 60kHz line scan. We had a utility that ran a VGA card over the whole range from 15Khz to some very high frequency. I still have a copy with source code on one of the computers here.
On post XP computers it appears as a box that stretches and squeezes on the desktop and does not output the correct scans to the monitor. DOS or early Windows is needed. |
