Old 5th Mar 2021, 10:44 am   #1
ITAM805
ITAM805's Avatar
Default Lamp ID
hi folks
can anyone identify this vintage lamp's original purpose? The bulb is a MES 4.5V. I'm guessing it's 1940's vintage.
thanks
ID:	228283   Click image for larger version
ID:	228284   Click image for larger version
ID:	228285   Click image for larger version
ITAM805 is offline
Old 5th Mar 2021, 11:01 am   #2
Refugee
Refugee's Avatar
Default Re: Lamp ID
It looks like a push bike lamp.
Refugee is offline
Old 5th Mar 2021, 11:24 am   #3
ITAM805
ITAM805's Avatar
Default Re: Lamp ID
What with the swivels isn't it a bit over designed for that?
ITAM805 is offline
Old 5th Mar 2021, 11:48 am   #4
Heatercathodeshort
Heatercathodeshort's Avatar
Default Re: Lamp ID
LUCIFER. I think it may be a Swiss Bicycle lamp. J.
Heatercathodeshort is offline
Old 5th Mar 2021, 11:50 am   #5
The Philpott
The Philpott's Avatar
Default Re: Lamp ID
I believe the brand is 'Lucifer' which does suggest a bike light. 4.5v could either be dry cells or dynamo, but probably the latter..?
Dave
The Philpott is offline
Old 5th Mar 2021, 12:11 pm   #6
duncanlowe
Default Re: Lamp ID
The swivels will give you various mounting options. My first thought was also bike. It would be unusual for the battery pack to be remote on a lamp like this so I'd agree more likely dynamo.
duncanlowe is offline
Old 5th Mar 2021, 12:15 pm   #7
Nickthedentist
Nickthedentist's Avatar
Default Re: Lamp ID
Definitely a bike light, I'd say.
Most of the ones we see here are Sturmey Archer. Even some of the dynamo ones had a separate battery pack too, so that the lights didn't go out when stationary.
N.
Nickthedentist is offline
Old 5th Mar 2021, 12:23 pm   #8
ITAM805
ITAM805's Avatar
Default Re: Lamp ID
Thanks guys, unanimous it's a bike lamp then. I can't imagine that being very bright on a Swiss mountain road though
Nick, yes I had a Sturmey Archer dynamo front and rear lamps on my bike in the 1960's, looking back it was pretty dim unless you pedalled really fast
ITAM805 is offline
Old 5th Mar 2021, 6:17 pm   #9
broadgage
Default Re: Lamp ID
Cycle dynamo lights are commonly 6 volts, not 4.5 volt, but of course the bulb fitted might not be the originally intended type.
Cycle dynamos are designed to supply a roughly constant current at any reasonable road speed. 300ma and 500ma were common ratings, but others existed.
broadgage is offline
Old 5th Mar 2021, 7:37 pm   #10
merlinmaxwell
merlinmaxwell's Avatar
Default Re: Lamp ID
My first proper bicycle in about 1972 had a hub dynamo (should have been called an alternator, that what it was) along with a battery tube for 3 D cells. On top of that was a bridge rectifier and a single diode to prevent back charging of the battery. And yes, it was to provide light when stopped, the law was changed (in the UK) quite a while later. BTW the rectifier and diode where selenium.
I think the item is a splendid thing.
merlinmaxwell is offline
