14th Jul 2018, 10:47 pm | #1 |
OMY - what are these devices?
I found these OMY120, OMY122 and OMY125 devices when going through a tray of components a friend gave me. They are packaged in a 10 pin TO-5 style case and could possibly be RTL or DTL logic gates made by Philips or Mullard.
I cannot find a data sheet for that family of devices on the web or any reference to them in the Mullard catalogues I have to hand. Can anyone identify them please. Thanks Ron |
14th Jul 2018, 11:34 pm | #2 |
Re: OMY - what are these devices?
Not that much help from an Italian web site -
"Mullard has done it lately some new types of integrated circuits DTLs including the OMY range and the FC range, which are presented in TO-5 ten-terminal housing. There range .OMY, designed for use in small computer systems and in equipment control clusters, is composed of two series: the OMYIOO and the OMY120, iden¬ tics between them except for the tempe¬ operating ratures ranging from -55 ° C to 4-125 ° C for the OMYIOO series and from 0 ° C to +75 ° C for the series OMY 120. Both have a typical time delay by stage of 23 nsec and can bear a dissipation of 18 mW for logic threshold; the margin of noise extends up to 950 mV a 25 ° C." |
15th Jul 2018, 12:50 am | #3 |
DTL... Diode-Transistor Logic. Pre-TTL stuff
15th Jul 2018, 8:36 am | #4 |
There is some information on page 11 of Philips "A Brief History of the Southampton Plant 1956 - 1996".
http://pepnet.org.uk/yourarticles/So...on/History.pdf "In 1965 a basic form of DTL (Diode Transistor Logic) was put into production. ... During this period, production commenced on the OMY100 range of multi-chip gates and "flp-flp" circuits" Also mentioned here: http://www.wylie.org.uk/technology/c...h/monolith.htm David |
15th Jul 2018, 9:25 am | #5 |
And the thing that preceded even DTL was RTL (resistor transistor logic). RTL was used in the Apollo Guidance Computer. Nearly 3000 flat pack ICS, all three input NOR gates. About 4kb of core store for RAM and about 75kb of core rope memory for fixed program ROM.
Slightly off topic, this is the best series of videos from a guy who has a complete set of Apollo AGC rope memories that flew on a test flight, how he reads them, and in the second video there is a Raytheon film about how they were made https://www.youtube.com/watch?v=WquhaobDqLU |
15th Jul 2018, 9:47 am | #6 | |
I did electronics at Southampton University, and one of my best mates got a job at Mullard Southampton when he graduated. He was given the job of CV (capacitance-voltage) testing MOSFETs, which were part of their logic IC programme (it is in the above link - mid to late 1977). Now my mate, being rather bright and only 21, did not like a mindless repetitive job. So he developed a machine to automate it, skunkwork-like, out of hours. He then went to his boss and said, look at what I've done here - what would you like me to do now? Expecting to be given the next thing to automate, or at least something else more interesting to do. "No - your job is CV testing". Not surprisingly he resigned, pretty much on the spot. A very few years later he joined the early stage of Microsoft in software development for Win 2.0 (and of course moved to the US), got shares each year, and now owns a huge house and a massive tract of land. So in a very real sense, Mullard did him a massive favour. Craig |
15th Jul 2018, 1:47 pm | #7 |
OMY - that must have been before a pro electron standard was set for logic circuits. After the standard was set, Philips pretty much only used pro electron designations (or pre production codes with letters OM behind the number) for ICs and OM designations for hybrids. It seems to me those are real ICs.
15th Jul 2018, 2:34 pm | #8 |
Or does it fit in with their OM prefixed hybrids like the VHF amplifiers currently plagueing Marconi test gear?
15th Jul 2018, 4:36 pm | #9 |
There weren't any overlaps I'm aware of, so in that sense it fits in quite nicely. The difference is that in the days of OM100/OM200/OMY100/OMY120 the later pro electron designations weren't used yet, so while later OM numbers are mostly hybrids, those early OM's were real IC's.
I'm maintaining an active list (OMY will be added shortly) at https://www.circuitsonline.net/forum/view/113864/1. Unfortunately, I haven't always specified whether a chip is a hybrid or a real IC. |
15th Jul 2018, 4:58 pm | #10 |
Hmm, now what is the definition of an IC?
The word 'Microcircuits' gives a sense of scale without saying whether it is a construction on alumina or FR4, or all in one piece of silicon. 'Hybrid' says that the active devices aren't of the same lump that acts as the substrate. 'Monolithic' says that everything, substrate, devices etc are made from one lump of whatever it may be. 'Thick film' hybrids usually means that resistors at least are made by deposition on the surface, and that normally needs a substrate which can survive firing. I think of real ICs as being monolithics, and then all the rest get fuzzy borders. David
15th Jul 2018, 8:08 pm | #11 |
I agree. I'll try and remember to use the word monolithic where appliccable
15th Jul 2018, 8:15 pm | #12 |
I think we can blame the Romans and the ancient Greeks, roughly 50:50
15th Jul 2018, 11:57 pm | #13 |
Thanks to everyone for their interesting replies. I have been up in the (hot) loft and located a Mullard Designer's Guide (i.e. short form catalogue) from 1965 and the OMY devices unsurprisingly are not listed, confirming they were introduced after that date. I also found a later one, now called an Industrial Products (short form) catalogue dated 1969/70 and the logic ICs offered are of the FJ.. series in DIL packages.
I'm sure that I had a plain blue and black coloured Mullard short form catalogue dated in between 1965 and 1969, but I could not find it. Ron |
16th Jul 2018, 11:43 am | #14 |
It would satisfy curiosity to know exactly what these are- type/number of gates etc.....
1st May 2020, 7:38 pm | #15 |
I've found the blue and black catalogue mentioned in post #13 whilst looking in the shed for something else. It's titled Mullard Industrial Semiconductors Quick Reference Guide 1967/68. The page I have posted identifies the OMY device functions and has a few parameters mentioned, including apparently the need for a +/- 6V supply.
It says that the main data is published in Volume 7 of the Mullard Technical Handbook, presumably for 1967/68. If anyone has this volume, it would be useful to find out the full data and the pin-out details for the 10 pin TO-5 style packages. The devices I have are OMY120 3 input DTL (diode transitor logic) NOR/NAND gates, OMY122 bistable steering circuits and some OMY125 five diode logic gate input expanders. The FCH series DTL following the OMY data seems to have more gates per package and is presumably a later generation of DTL. Ron |
