1st Jul 2017, 3:03 pm | #1 |
Unmarked valve #1.
Hi, Can anyone identify this valve, please?
Thank you, Jacek PS. I have more unmarked valves, next one in a week. Let me have some fun too... |
1st Jul 2017, 4:07 pm | #2 |
Re: Unmarked valve #1.
Hard to see on my phone help to know what the base is but looks similar to an 807
1st Jul 2017, 4:15 pm | #3 |
Looks like a grid top indirectly pentode.
1st Jul 2017, 5:59 pm | #4 |
B7 base? Or is it american UX? What heater volts? Separate cathode i.e. indirectly heated?
I can't get the 3rd pix to load. Last edited by Boater Sam; 1st Jul 2017 at 6:01 pm. Reason: added no pix |
1st Jul 2017, 6:11 pm | #5 |
Looks like two heaters in series, is the centre tap brought out to one of the valve pins?
There's also some writing on the pinch but I can't quite make out what it says yet. Lawrence. |
1st Jul 2017, 6:26 pm | #6 |
Not 807 I don't think as wrong base.
1st Jul 2017, 9:52 pm | #7 |
Mazda construction, probably an AC/6 Pen.
Leon. |
1st Jul 2017, 10:35 pm | #8 |
Is it on an International Octal base? If so, it could be a 12E1 or one of the similar variants.
Al. |
1st Jul 2017, 10:45 pm | #9 |
I suspect it's a B7 base, they usually have a split which can be seen.
1st Jul 2017, 11:31 pm | #10 |
It looks like its written on the pinch! I think this is a Mazda trait although the very plain anode structure looks odd.
2nd Jul 2017, 4:48 am | #11 |
This is the 12 volt heater version of the 807, the 1625.
2nd Jul 2017, 5:35 am | #12 |
We can definitely eliminate the 807 and 1625.
The third picture shows a connection from the anode going downwards into the pinch. The 807 family have top cap anode connections only, and have ceramic insulation bushes for the anode supports rather than relying on the micas alone. So the top cap must be something else, probably G1, which is rather peculiar in a large-ish power valve. Those look like beam-forming plates within the anode, yet the anode construction doesn't optimise heat dissipation in the target area. This looks either a very early beam tetrode or else a 'power pentode. AC6/Pen doesn't have a top cap, the 7 pin base is enough for an indirectly heated pentode. So if there is a centre tapped heater, then one electrode would be pushed onto a TC to free a pin for it. David
2nd Jul 2017, 7:54 am | #13 |
The AC6/Pen has a top cap anode. Mazda valves were better built than those of many of their competitors and one feature was rigidity.
Frequently, a support pin is anchored in the pinch without a corresponding lead being connected to it. Thus the anode assembly is held in the pinch and the "heater centre tap" may not actually be connected. The AC6/Pen still gets my vote. Leon. |
2nd Jul 2017, 8:37 am | #14 |
2nd Jul 2017, 8:43 am | #15 |
Does the OP actually want to know or is the fun aspect "the thing"? Both valid by the way!
It would be useful to have some measurements from pin-to-pin. What is the (cold) heater resistance? Is it connected to any other pin (the centre tap theory)? Any other pins linked to each other? What current does the heater take (& hence voltage across it) when "glowing nicely"? Having identified the heater, which pin has the greatest measured capacitance to it? - should be the cathode. What other capacitance values between pins? Forensics! Graham
Half my stuff is junk - trouble is, I don't know which half! |
2nd Jul 2017, 8:59 am | #16 |
Sorry, Leon, but that anode connection isn't mounting rods into the pinch, it looks like it would offer very little mechanical rigidity with thin wire, a couple of right angles and some iffy looking weld. The TC could still be anode, but someone put extra work into that downwards connection.
Oddly Radiomuseum shows all electrodes to base pins then says it has a top cap but gives no mention of its connection r-type says the TC is anode, shows no anode connection on the base, of course, and two unused pins. A TC anode for TV line output is definitely a good idea. It fits except for the flimsiness of the anode to pinch connection. good puzzle! David
2nd Jul 2017, 9:37 am | #17 |
I am happy that you like that puzzle. On the pinch is "Pen WO/28/S".
I got this valve from G4JQT. (Once again, Thank you, Ian) Adding more photos, taken with different light, but I am going to use a polarization filter next time. Thank you Jacek Last edited by JacKam_; 2nd Jul 2017 at 9:43 am. |
2nd Jul 2017, 9:46 am | #18 | |
http://collection.sciencemuseum.org....endd4020-valve Can't find a clear glass version of it though. Cold heater resistance should confirm if it's a 40 volt heater. Lawrence. |
2nd Jul 2017, 10:04 am | #19 |
David, you're quite right. I had missed the non-supportive anode connection.
Lawrence, I think you've nailed it. I have just checked a PenDD4020 and there are many similarities. My sample has a graphited coating on the inside of the bulb, which may not have been applied to the earlier versions of this valve. Viewed on a better monitor, I can see two horizontal connecting bars below the pentode which may connect the 2 diode sections to the pinch upright rods. A better picture of the top of the valve would then confirm the top cap connection as being g1. Interestingly, my PenDD4020 sample also has the "heater centre tap" - not connected below the pinch. No doubt the high heater voltage versions had a long heater coil which Mazda wisely supported at its centre. There's no connection to it. So, almost nailed. There was, however a PenDD4021 which was a higher current version. A test to distinguish this from a 4020 would have to be made electrically. There were also a couple of Mazda odballs - a 12V version for (monster?) car radios and a 6V version for Philco. As Lawence suggests, a heater test, preferably by running the valve up on a power supply should find these. An interesting puzzle - we need confirmation that early versions of these valves were not graphited internally. Leon. If you look at the top cap, there's good evidence of the solder fatigue which these valves suffer from, which I detailed in another post. Reflowing the joint usually fixes them for another 70 years. |
2nd Jul 2017, 10:45 am | #20 |
Consumed with curiosity, I've just opened my Murphy A30C which uses an AC/2PenDD.
On examining this valve, there's no heater centre support (it has a 4V heater) but the construction is otherwise very similar. This original pre-war green type valve is graphited internally. I re-flowed the joint to the cap. Leon. |
